- Joined
- Jul 12, 2024
- Messages
- 3,765
- Likes
- 5,967
You seem like you need a hug. Why on earth do you care what other people do with their systems? It's odd to be so invested.Hearing damage speed run.
I think the key here is extended listening.I'm going to chime in with those curious about the need for greater SPL. I usually don't listen loud, but my room is similar size (higher ceilings) and if I crank my 8Cs up they are truly punishing, even in the low bass region. Extended listening in that volume range in this room would result in rapid and irreversible hearing damage.
I'd humbly suggest taking a look at the Pitt & Giblin SuperWax Mini, I've had mine for about 2 months and I'm very pleased.Hey everyone,
Looking for some real-world input on replacing my Dutch & Dutch 8cs as front L/R mains.
To be clear: I love the sound of the 8cs. I just want more output capability, crossed over at 80 Hz to subwoofers handled by external DSP/room correction in the Altitude CI. The two contenders are the Perlisten S7t Black Edition and the KEF Blade Two Meta. The room is probably slightly more movie use with the family vs me listening to music solo. It is a multi-purpose room that we are overall very happy with.
Room & Placement Constraints
- Room: 20.5' L — 14.5' W — 7.5' H
- Placement limits: Maximum 2.5' from the front wall and 2.5' from the side walls. No flexibility here due to the screen, false wall, and room layout.
Thanks for any insights.
Second. It also strongly relates to the content being played. E.g. with some modern hip-hop, 85dbA at the MLP translates to 100+dbZ, which will very quickly kill any woofer not capable of true unconstrained reproduction of VLF. It’s really easy to end up listening to (some) music at 95-100dbZ for brief periods of time if the speakers are truly capable of it and thus invite you to do so - even in smaller spaces.I think the key here is extended listening.
Over the last 50 years or so I have typically had systems capable of >110dBC at the listening position. While I typically listen at ~75-85dBC, on occasion I will blast the sh** out of certain tracks from time to time. I must say that while my D&D 8Cs are capable of deeper bass than most of those previous systems, their max SPL of around 101-105dBC is limiting and they do not hold up at those levels as well as the much larger systems I have had in the past.
and very beautifulVery powerful, dynamic speaker-
I learned a long time ago that dBA has little bearing on music level and much more so today as you point out about genres, but I would suggest it isn't limited to genres. Modern recordings as well as contemporary live shows have substantially more low frequency content that we typically saw in last the century.(At first glance I thought you wrote dbA and wanted to interject that nobody listens to music this damn loud)
Isn't it the whole point of the thread that we are giving the OP input into what to do with their system?Why on earth do you care what other people do with their systems?
The input the OP was asking for was which speakers would be best for increasing the SPL of his system.Isn't it the whole point of the thread that we are giving the OP input into what to do with their system?
Yes, exactly.The input the OP was asking for was which speakers would be best for increasing the SPL of his system.
I find it hard to disagree on both counts, point taken.I learned a long time ago that dBA has little bearing on music level and much more so today as you point out about genres, but I would suggest it isn't limited to genres. Modern recordings as well as contemporary live shows have substantially more low frequency content that we typically saw in last the century.
Regarding your JBL recommendations, I would fine tune that. The M2 and others with D2 drivers do not play loudly as well as the older large format based systems. This is likely why JBL's new Summit series use those multiple entry horn throats with multiple HF drivers.
If I had the room JBL M2's would still be my end game speakersTo be clear: I love the sound of the 8cs. I just want more output capability, crossed over at 80 Hz to subwoofers handled by external DSP/room correction in the Altitude CI. The two contenders are the Perlisten S7t Black Edition and the KEF Blade Two Meta. The room is probably slightly more movie use with the family vs me listening to music solo. It is a multi-purpose room that we are overall very happy with.
www.sigbergaudio.com
I don’t think this is correct.If additional subwoofers are used, the cardioid radiation pattern offers less benefit below the crossover frequency. With DiracART, only one subwoofer (or a subwoofer group connected to a single subwoofer output on the AV receiver) handles the LFE channel, while the remaining speakers and subwoofers (only) provide support below 150 Hz.
I had a listen to the 4365 in a big conference room. At least 60' x 30' and they went very loud without any sign of strain whatsoever. They could easily make you stone deaf in a 14 x 20 room and they'd still only be ticking over.In general, the recommendation was based on Erin’s compression tests of the 4367, which looked good - and with music, the woofer(s) will pretty much always be the bottleneck of the system. The D2 has a bit more distortion than necessary, but it’s H2 and ought to be inaudible in practical use. I haven’t heard the M2/4367, so this is mostly a strong assumption.
LFE reference is about timing, and for that a speaker is selected (usually center) to time align with the subwoofers. Of all subwoofers Dirac selects one "main sub" (or subwoofer group connected to a sub-out of the AVR) which has the highest SPL contribution. All the other speakers/subwoofers are only used for support. To a certain extent, the contribution of the other loudspeakers/subwoofers can be increased by adjusting the support frequency range and the support level.I don’t think this is correct.
Only one subwoofer is used as LFE reference, but it’s still all subs handling LFE.
