Moving from Dutch & Dutch 8c for More SPL: Perlisten S7t Black Edition vs. KEF Blade 2 Meta?
Sorry man, I've been in that position in the past with the daycare situation. I bought some used definitive technology speakers on craigslist back in the day. I still remember those things. Hopefully you can afford any speaker you want some day.
I don't need high SPL so right now so my setup is definitely nothing to complain about, but either way $20k+ for speakers is not on the table at the moment... Would be nice to have a dedicated room and all that someday but for now I'm not itching to upgrade. Truthfully even if I had $30k to spend on speakers right now it wouldn't do me much good unless I also added 2 zeroes to that for a new house to put the speakers in. :)
My latest purchase is a MOTU M4 so I can try MIMO bass optimization in my office via umami perfect soup, apparently it is similar to Dirac ART but less than half the price. Definitely the shallow end of the pool budget wise but I think MIMO DSP is something anyone with more than 1 sub should be looking at to get to the next level. PEQ for room modes is cool but active cancellation is the next best thing to high end acoustic treatment.
And also the Perlisten S7t. To be clear, I could live with any of them and each had its own appeal. I did not choose the 8Cs simply because standmounts are aesthetically unacceptable for my room. I did not choose the Perlistens because three of such massive (for my room) enclosures was a problem. I was greatly impressed with their balance and dynamic performance. However, I could not adapt to the low placement of the HF although that may just be a visual bias. All that's in the reviews and personal acceptance is a highly complex decision that goes beyond the purely audible.
Don't you have the Blade2? The S7T are smaller than the blade2 if I recalled correctly.
That's a pretty small room for an 8c to not be loud enough in. Are ya'll just trying to blow out thine ears?
Do you listen to music with bass? An 8 inch driver isn't going to cut it at those distances.
The OP crosses them to subs.
Hey everyone,
Looking for some real-world input on replacing my Dutch & Dutch 8cs as front L/R mains.
To be clear: I love the sound of the 8cs. I just want more output capability, crossed over at 80 Hz to subwoofers handled by external DSP/room correction in the Altitude CI. The two contenders are the Perlisten S7t Black Edition and the KEF Blade Two Meta. The room is probably slightly more movie use with the family vs me listening to music solo. It is a multi-purpose room that we are overall very happy with.
Room & Placement Constraints
  • Room: 20.5' L — 14.5' W — 7.5' H
  • Placement limits: Maximum 2.5' from the front wall and 2.5' from the side walls. No flexibility here due to the screen, false wall, and room layout.
Thanks for any insights.
Interesting, your room isn't that big, 27 m2. Maybe you're in a null?
The crossover frequency with the sub is also strange. The Dutch and Dutch 8C, if I remember correctly has crossovers at 100 Hz and 1250 Hz. The rear woofers handle everything below 100 Hz, and in so far as I'm aware, 8" is good enough at high volumes for above 100 Hz. But you're also very much under utilising the woofers of the 8C by having the sub take over so early.
The only reason you might hear higher distortion on the 8C is if the cardioid ports somehow exhibit from form of distortion at high volume.
I'll agree with the others that measuring your speakers would be a good start.
Never mind, movie mid bass can reach extraordinarily loud levels. Let me suggest the Sigbert Audio Manta then.
Does anyone have experience with Alcons audio? The CMRS compact looks great as well.
Wait for the 15C ? :facepalm::)
So no then, gotcha.
I figured you didn't listen to bass content, that's why you think an 8c can fill a room that size by itself.
Plus you are patronizing the op, I think adults can make their own decisions about how loud they listen.
You said and 8". You know there's 4 between a pair of 8c right? Now that we have that basic info out of the way...
I write electronic music lol, so you've got the wrong guy on the bass department.
It's not patronizing to suggest that one might have some sort of setup issue as I have a room that is nearly the exact same size and a simple ported 6.5" woofer two way can fill this space with A LOT of bass.
Welcome to my ignore list. Take care.
I'm likewise skeptical... To me bass includes the bottom octave and you're not getting much of that from a 6.5" at good SPL. I guess you could bust out the mic and show us?
Technically, there are six 8" in a pair of 8Cs. Two at the rear, one at the front per speaker.
However, as far as how the OP has set them up, I figure the bass duty is distributed so:
< 80 Hz: dedicated subs.
80 Hz -100 Hz: rear woofers
100 Hz and above: front woofer.
The front woofer is still handling a good amount of work, but suffers from decreased efficiency from the cardioid port loading, the side vents still producing cancellation signal to the front, and reduced room reinforcement in the mid/upper bass. So yeah, that front 8" might the a weak point.
Hi all thank you for the responses.
I read about the C8C in the past and completely forgot about them. Maybe I should consider them. I also should update my signature because this is a multi-channel music room. Current set up is 7.4.4 and I have all KEF surround/atmos channels. The KEF are CI2000RR/RS for in wall/ceiling and Q11 metas for rear surround. I have the R6 Meta as a center channel which I am happy with.
IMO that means your next L/R speakers should be KEF R6M too. Or change out all 3 for something else identical.
I am familiar, I have made a few passive cardioid speakers.
I understand everyone has different expectations in SPL and distortion, but I'm sitting in a room the same size as OP's and just not understanding their SPL requirements. They must want hearing damage levels or something. Even a mechano23 will get uncomfortably loud in a space this size without much strain. I don't know if people realize how small this size of a space is.
I will not be sharing any data on my speakers in my room here as it's not relevant at all the discussion. If want them, PM me.
Mort just listens super loud, they regularly hit the limiter on their Genelec 8631a in a smallish room. :eek:
