Having owned the audients ID series which are or was a notch higher than the Evo and owning the Motu Mk5 and having heard quite an amount of other
I assume from the MOTU I'll get the sound of Audient EVO line, maybe slightly more refined.
But in the Audient iD line, the preamps do the mojo stuff.
interfaces (again only speaking for me) my personal opinion is that you will never hear any serious difference in normal tasks between any halfway decent interface.
Like if you playback music and connect speakers-monitors , you will not hear a difference in „resolution“ or in general audio quality unless your aim is to hear differences.
The Instrument Preamps are a different story as there you have headroom, what they add, what they can take and stuff like this.
"MOTU I'll get the sound of Audient EVO line, maybe slightly more refined“. if it helps you psychologically i would say totally go for it. I have also bought
things in the past where i could not hear a difference but thought „But what IF“ .
Makes no sense to buy the Evo and constantly asking yourself „but if“ even if you hear no difference. Might sound abstract but i hope you understand how i mean it.
Thats why i can only speak for myself. 1) Monitor Quality 2) Room acoustics 3) Everything else. Interfaces are Way overrated when it comes to tech data or better said to actually perceivable audio quality
„Oh this one has o gazillionth less distortion“ are usually measurements no one notices in real life usage.
Anyhow. I wish for you to find the best solution for your taste and needs. I can only offer an opinion. Not a solution
