It still feels warm. Anything device can be can cool down, is always a good thing and the fan is $29. I don't see why not, or will you be replacing my Motu when it goes bad one day? lol
I believe this is an example of the Dunning-Kruger effect.
Do you know how much the retail price would increase if the BOM increased is by $29?
A computer or gaming console cooling system needs to dissipate approximately 200-800 watts of heat.
Interface like this is 10-15 W at max.
Passive cooling in completely silent (which is important in recording environment) and doesn't include moving component which can fail.
Actually I consider passive cooling as a premium.
In my opinion, MOTU can certainly be considered a competent company that designs solid performance products for professional use.
And every competent electronic designer takes thermals into account when designing circuits. When used as intended, they should not fail or require additional cooling.
Professionally I design automotive ECUs, e.g. BLDC driver passing up to 200 amperes. It operates in much harsher conditions of engine bay and it works perfectly without a fan.
Believe or not, they're designed to operate at an temperature of 135°C and not fail for at least 150 000 kilometers or 15 years.
Unless you expose your MOTU interface to direct sunlight or live in a tropical climate, I don't think you should worry about additional cooling.
BTW. You'll be shocked to find that some devices perform better at higher temperatures and even benefit from additional heating
1) no, DSD there made from PCM. 2) yes. 3) single, and today I finished APU modification - LPF is deleted, 48VDC phantom power added. Also, I bought cheap but seems quite typical Rode NT1 to find the optimal gain APU's switch +?db/+60db. 3.5mm jacks. 4) no such plans so far to make ADC/DAC...
www.audiosciencereview.com
