I see from your dmesg content that it actually creates a network interface too. Did you try configuring it and connecting to it at all?
When you say 'the IP address of the interface' which address do you mean? The address of the network device enx0001f2fff075 as presented on the Pi, or the address of the Ultralite at the other end of that virtual network cable? We've got an unfortunate overlap with different meanings for the word 'interface' in overlapping contexts. Also I'm guessing Cuemix was running on a different machine on the network, so did you configure the Pi to act as gateway between the networks?Only thing I've tried is entering the IP address of the interface in Cuemix (also tried using the Pi IP address) but it does not connect. Have not explored it further. Having the ability to change the clock source remotely would be beneficial as currently if you switch between USB, SPDIF and TOSLINK inputs you need to either manually change it on the MOTU itself or use Cuemix.
Michael
The 169.254.x.x addresses are so-called automatic private addresses assigned by the device itself which indicate that the device cannot connect to a dhcp-server to get a proper address. Normally you would see something beginning with 192.168. if using default settings in your network.Have not configured the Pi to do anything special and have also tried this with the MOTU connected to a Mac and trying to use another Mac or iPhone to connect via Cuemix.
The MOTU itself shows an IP address, see below.
That's less than convenient as floating ring cables seem to be pretty rare. I was just trying to find a 3.5mm TRS to 2x 1/4" TRS breakout cable and they seem nonexistent, let alone floating ring. 3.5mm TRS to 2x 1/4" TS cables, on the other hand, are everywhere. Probably going to have to make my own at this rate.
In a balanced connection Tip is normally (+) and ring is (-) with the sleeve grounded. So going into an unbalanced input they don't want the ring grounded out to sleeve (which is usually how such cables are made). So you'd want to disconnect the ring connection. Or that is how I read it.
TRS-2xRCA cables are readily available. The white side connects to the positive pole, and the other pole is left floating. Female RCAs are preferred, so that the connectors are not touched by accident.That's less than convenient as floating ring cables seem to be pretty rare. I was just trying to find a 3.5mm TRS to 2x 1/4" TRS breakout cable and they seem nonexistent, let alone floating ring. 3.5mm TRS to 2x 1/4" TS cables, on the other hand, are everywhere. Probably going to have to make my own at this rate.
Sorry but English is not my strong point ... someone kindly explains to me what this wording in the manual means?
Quarter-inch line outputs are not cross-coupled. Therefore, when connecting them to an unbalanced input, use a TRS plug with the ring disconnected. Not floating the negative terminal will short it to the sleeve ground and cause distortion.
Which is the ring to be disconnected?
The quarter-inch analog inputs (5-8) and outputs (1-8) shown in Figure 4-4 are balanced (TRS) connectors that can also accept an unbalanced plug.
Review of the UL Mk5? If so, it's stellar!Does anyone have a review on this as of late? Any updates? Pros and cons?
ESS hump has never been an audible issue with any Dac. Its just a nerdy technical thing because between tho devices with same price and functionality you want to pay for the better one, thats it, it doesn’t mean you will hear it, nobody could discern by ear that bump as long as the overall distortion is as low as this one.Hi guys. Do you think the ESS hump problem @amirm comments is really audible? Would you still recommend the interface despite of this? How does it relate to other interfaces such as the Clarett? Does the Clarett for example also suffer from IMD problems?
I will look closer this thing, because I still have a 828 MK2, supposed to accept both like your Traveler, but even if I did not did a listening test, I saw that measurement software like DeltaWave can see a difference between the same source in unbalanced or balanced mode.strange. my older Motu Traveler MK3 can be used unbalanced with simple TS connectors:
The loopback test done on Gearspace and processed in Deltawave with result on this page shows the same RMS difference with GS test and DeltaWave test for balanced and unbalanced, but the PK Metric is a lot higher in balanced.
I checked it as the one on Deltawave page is a unbalanced capture, so I did both and got 88 in unbalanced and 108 in balanced (which matches the Motu 2408 MK3 and 24I/O using same chips).
Need to check if it's audible now, I don't think on one capture, maybe once summing a lot of tracks captured like that...
