JimmyBuckets
- Joined
- Jan 12, 2021
- Messages
- 213
- Likes
- 170
Can probably get a 8 channel mixing board for $90 new or on face book for super cheap.
With similar specs as the Motu preamps? (noise, THD, DR)Can probably get a 8 channel mixing board for $90 new or on face book for super cheap.
What's the noise, THD, DR of your mics? LOL. You're a trip brother.With similar specs as the Motu preamps? (noise, THD, DR)
I doubt it.
Thanks I wasn't aware! I actually found a thread discussing this:Most interfaces can be used stand alone as mic preamps. You may need to connect to a pc to set routing then use stand alone.
www.audiosciencereview.com
The Behringer 8port mic pre rack they have is ok. Lots of mic preamps but yeah, clean stuff is not cheap lolSo I own an M4 and I need to record 3-4 mics at the same time. I'm looking at some extra preamps that I can plug into the M4 without breaking the bank.
Anyone has any recommendations?
Seems difficult to find a couple of budget clean preamps (not using tubes) these days as almost nobody manufactures this anymore. Focusrite and others bundle 8 preamps but it's overkill for what I need.
I've seen the Tascam US 2X2HR (or the 4x4HR) can be used in fully analog standalone mode and their Ultra HDDA preamps are great. For about $150 this seems a good option.
Audio interface with standalone preamp mode
I'm interested to know what audio interfaces out there can be used as standalone analogue preamps without a computer. Of course it's main use will be with a Mac, but I'd like to have the option. Quite a lot ( Motu m2 and m4, Audient EVO etc.) can be powered by a usb battery or adapter and...www.audiosciencereview.com
Hello all,
Thanks for the wonderful review and very interesting thread. I also enjoyed reading the teardown thread as well.
With regard to hi-z sources...
Would going through an external preamp [such as a Camden EC1] and in via 3/4 result in a clearer signal?
Thanks in advance.
Thanks. I'm thinking about it because I want to use some line level gear. That saturation circuit does look interesting.I doubt the Camden EC1 will give you a more clear signal.
It might give you a better sound. I've tested dedicated DI boxes vs hi-z inputs on interfaces and I've heard electric basses getting a bit more low end and fuller sound. Nothing dramatic though.
The Candem EC1 will also allow you to get a less cleaner signal with the saturation circuits it includes.
In short, I don't want to sacrifice fidelity if I need to attenuate the M4 output volume to 70% or so.
I have something similiar I'm currently setting up. I have a PC connected to the Motu M4, which is connected to two SVS SB2000 subwoofers and an old Arcam A32 integrated amp in HT bypass mode.My current setup is DAC Topping D10 + Headphone Amp JDS Labs Atom + Amp Aiyima A04 + 2.0 Speakers (passive) Elac DBR-62. Everything unbalanced. I want to swap Topping D10 for Motu M4 and add 2x Monoprice Thx 10" sub, making it 2.2. Will I be able to control the volume of the speakers and subs from Windows simultaneously? I see that I can configure the crossover physically on the subs but what about the speakers, can I do it for them in Windows, without buying any extra devices? Finally, can I have both the speakers and subs EQ-d at the same time? Currently using Peace EQ.
Care to elaborate?I bought Motu M4 but it sounds much worse than my old ESI Juli@![]()
Download this free null testing software. Record a song of 2 or 3 minutes from each device and compare the results to see what any differences are.It's hard to explain. I bought it yesterday. While the Motu M4 looks good on paper, it has very poor output quality. Unlike M4, ESI Juli@ has excellent sub-bass, clarity and fidelity. The difference is like day and night and it's quite noticeable on my Yamaha HS8 and Sennheiser HD599. I'll try to record their outputs for comparison.
HiIt's hard to explain. I bought it yesterday. While the Motu M4 looks good on paper, it has very poor output quality. Unlike M4, ESI Juli@ has excellent sub-bass, clarity and fidelity. The difference is like day and night and it's quite noticeable on my Yamaha HS8 and Sennheiser HD599. I'll try to record their outputs for comparison.
