motorized speaker stands? An untapped market.
The only use case I'm thinking of is pretty darn niche: raising and lowering a stand-mounted Center bookshelf speaker.
My first thought was as built in speakers, in a room with multiple functions. Raise the speakers up for use, lower them into/behind furniture.
Second thought, lower for seated listening, raise them up for room/house filling sound.
Third thought, the profit margin on a lift mechanism goes WAY up when you make it audio specific.
Fourth thought, I've already thought about this too much.
I think it might make sense to have speakers move away from the wall to a defined position for listening automatically.
So you can have the near wall placement for the looks but when you sit down these move out. Additionally hook up the DSP in a way that it adjusts to both positions.
When you look at what people pay for interconnects and speaker cables this is way more effective and might even be cheap in comparison.
Horizontal movement away from walls is already cheaply 'solved', at least to a degree , without motors (i.e. not automatic), by attaching speakers to wall-mounted articulating arms like this one, repurposing it for audio instead of TVs.
I deployed these in a small former room as a COVID project, and helped set up a friend with them in his living room.
It's a cool 'standless' look and sturdy enough to support normal-sized bookshelf speakers (you do have to know how to attach stuff to walls securely).
It allows one to easily tinker with distance from rear and side walls. Maximum extension is 16" straight outward (and then factor in another 8-10 inches to the speaker faceplate), a bit less if you 'toe in' or otherwise angle them toward or away from side wall. They fold away compactly to the wall if need be.
You are of course locked in to whatever vertical height you choose* (though the attachment plate can tilt up/down through 18 degrees.)
However it seems Amazon doesn't sell them anymore :<
(I still have mine, in storage)
*unless you get very clever and mount them to vertical rails on the wall. Which I did not think of at the time.
Imagine one with wheels, that you could remote control to position!
Then comes AI and built-in room acoustics sensing, and the thing can move itself to the optimum spot.
The future!
(seriously, all that would actually be useful for subwoofers)
Then it could turn on it's cameras, and report you to Big Brother!
