But thinking in absolute terms why would you just a less fundamentally less perfect shape if there's no real need? I still don't get it. ;)
So, I don't know exactly, but I suspect that, in simple terms, both Genelec and earlier KEF models used oblong (“racetrack”) woofers not because the shape is inherently superior, but because it addresses practical system-level constraints more effectively than a round driver.
A racetrack diaphragm allows for a more effective cone area within a limited baffle width or height, which could help maintain a compact front geometry and better overall integration—whether that means preserving controlled directivity around a coaxial driver in Genelec designs or fitting substantial bass capability into relatively slim enclosures, as with the KEF B139B.
Since these drivers are typically used in the bass region, where wavelengths are long, their geometric disadvantages are largely irrelevant in practice. The same reasoning applies today in modern soundbars, where the extremely low profile often necessitates elongated drivers simply to fit sufficient diaphragm area into a very shallow form factor.
An additional side effect is that membrane resonances are no longer rotationally symmetric but spread across different modes along the long and short axes, effectively distributing and shifting potential breakup behavior instead of concentrating it into a single dominant peak, which can make it easier to manage.
That would be my explanations.
We need to develop non-round vinyl! :cool:
I know you are joking but one bit of engineering I was peripherally involved in was where a top plate mode of a record deck had one of its modes with an anti-node where the arm mounted at a sufficiently low frequency for the mode to show up on the headshell. Obviously this lead to inaccurate transduction since the headshell needs to be a stator at audible frequencies.
The solution was to do a modal analysis of the top deck and find somewhere to put a hole, out of view, which changed the mode shape to move the anti-node to a less harmful location.
The production cost of doing this was small. Nowadays it is almost mandatory to build a macho record deck selling for a gazillion pounds which may be no better and never had any dynamic analysis done anywhere near it.
Bingo, it was chosen as a best case compromise to fit in a desired cabinet shape and space.
Same principal why it dominated auto use for years, the rear package tray and dashboard of a car, it just fit that space better than anything else at the time.
Vance Dickason describes the effect of a not round but elliptical driver here:
The driver described in that paper is a tweeter, and its breakup modes may just make it at least the equal if not actually superior shape for that driver IDK.
Certainly a circle is a better shape efficiently move air, and much cheaper to make, but I wouldn't be surprised if a non circular diaphragm had easier to control breakup modes.
With a woofer, all you have to do is consider the large amount of pressure exerted by the centered voice coil on a diaphragm suspended at its parameter and it's pretty obvious to me that keeping the diaphragm itself from flexing and distorting thru what might be inches of movement, is a lot more difficult for an equally rigid material, when something other than a round design is used.
No doubt KEF and a few others have produced some excellent sounding speakers using relatively small racetrack woofers but yet the industry is almost completely dominated by round woofers.. Genelec's use of a racetrack woofer has been mentioned, but OTOH, look to Genelec's subwoofers and guess what they are?
images
There are midbass drivers in the Ellipticor range too, but the key design attribute is not an elliptical cone that you wanted to discuss, in fact they have circular cone diaphragms. The elliptical part is the voice coil and magnet. Any advantages to that design are off-point to the point you raised, Sal.
cheers
I think most vinyl is non-round. The times when center holes are punched perfectly centered, and fit snugly on the spindle are quite rare. :p
Probably more because they are so much cheaper to tool and make than non-round ones.
Follow the money ;)
Just a citiation out of the above linked article:
By not driving
the diaphragm symmetrically, but asymmetrically, what
you get is an “infinite” number of Eigen frequencies, but
with less contribution for each frequency and overall lower
distortion. Driving the diaphragm symmetrically you get a
finite number of Eigen frequencies with a higher contribution
combining at certain frequencies producing the “dreaded”
coloration modes
This could be translated into a diafragm's geometry too.
KEF and EMI were making oval bass drivers in the 1960s, they certainly can be at least as stiff and have less pronounced breakup modes.
I owned both KEFkit 3, which used the 13x9 "racetrack" KEF driver in the early 70s (and used by other speaker makers like IMF and Wilson) and changed them for Monitor Audio MA3 which had an oval EMI bass driver and were amongst my favourite speakers I have owned. (photo from internet)
Ha! That’s a photo from my own ad - of the very pair of Monitor Audio speakers that I sold for my father-in-law who had moved out of his house.
I’d listened to those speakers on and off for years at his place and they were one of my favourites.
Beautiful flooring. !
