Could you post a photo of the "better, smooth" type? I'm not sure I understand the difference.I guess, some may consider 'split' grains as artistic flair, but they detract from the natural continuous grains in wood (e.g. some MoFi veneers).
The guys at Volti Audio do some of the most beautiful veneer work I've ever seen. When I've viewed a few at shows they took my breath away.
Woodworking experts can do a much better job of explaining.Could you post a photo of the "better, smooth" type? I'm not sure I understand the difference.
If I am reading you correctly, you do not like book-matched veneer and would prefer to see veneer that is 1 continuous piece for each entire side?Woodworking experts can do a much better job of explaining.
If we have a veneer that needs to be applied to a 50mm-wide surface.
A 50cm-wide (1mm-thick) full-grain veneer would require a much larger tree (and probably equally large cost$: image foreground).
Or, you can just get-by with two 25cm-wide veneer strips; spliced side-side-by-side (butcher-block style: image background).
Else, you get a 2mm-thick (25cm-wide) veneer that is cut down the middle, so that the grains are matchy-matchy. (Previous photos)
I hope that makes sense.![]()
You must be one of those:If I am reading you correctly, you do not like book-matched veneer and would prefer to see veneer that is 1 continuous piece for each entire side?
Thank you.Woodworking experts...
Expert, no. But I do appreciate what can be done by a skilled craftsman and some exciting veneer.You must be one of those:
Thank you.![]()
One example is this Salk Song 3 BeAT with a Spalted Beech Veneer applied as a standard book match:
This is one of Salk's SS8 designs with a 4-way book matched Pepperwood Veneer:
And another Salk Song 3 BeAT with a book match Spalted Beech Baffle and 4-way book match Burl Walnut on the sides:
Everybody has their own taste. These are stunning to me.
I will agree with you though, I was not a fan of that earlier Speaker you commented on.![]()
I wish I could've done something like those veneers on my Speakers, but cost and size were both prohibitive, with size jacking up potential cost A LOT! (The Phil3 bass cabinet alone is 14sq.ft. of veneer, finished... per cabinet!)The veneers on the Salk speakers are beautiful furniture quality finishes.
They might be the very apex of audiophooley, although obviously there is fierce competition.
Very interesting diffusion panel on the center wall. Usually I think of diffusers as block-y or like all the plaster ornamentation in classic concert halls. I wonder how it works and how it was made?
Ruark speakers were super stylish with their woodwork and finishes.
Oh yes, I get what you were talking about now.Woodworking experts can do a much better job of explaining.
