somebodyelse
- Joined
- Dec 5, 2018
- Messages
- 5,798
- Likes
- 5,477
I'd be interested to know how that array is wired.
This is why, for example, the Grundig Monolith and the Heco Lab series were wired differently in the tweeter array.
I once had the circuit diagrams for this - I'll have to look for them.
The Trick is to get the drivers close enough together and stack the bottom and top of the wave guides as close together as you can. It mitigates most of the lobing.
They lob worse than any speaker I've ever listened to, and they were still a lot of fun.
Obviously, but exactly what mix? Is it using shading similar to the CBTs for example? It doesn't look like a bessel array. Do they use a crossover so only the centre one plays the top end and the rings come in progressively lower? Or do they just look pretty but have terrible directivity problems?You need a mix of parallel and serial topology.
Mich würde interessieren, wie dieses Array verdrahtet ist.
I was wrong...
Dies ist die Frequenzweiche und Schaltung des Monacor Lightning, der Bändchenhochtöner verwendet.Es kann jedoch funktionieren, wenn es sich um bandförmige Hochtöner mit sehr geringem Abstand zwischen benachbarten Hochtönern handelt.
This is the crossover and circuitry of the Monacor Lighthning, which uses ribbon tweeters.
f I remember correctly, it was a Bessel Array
Yes, I interpret it similarly.Never really tried such, but I would expect similar results regarding interference and lobing (directivity pattern and listening window might be different, though).
