One-line poetryEven your thoughts would echo
Easy to confuse with a vase or a cocktail shaker.Most beautiful speaker in my opinion? Beolab 8:
Placing a waveguide/horn into a baffle looks good. But it's not the better design for sound quality unfortunately.
The main speaker is practically blocked, and there's a reason for that
Yes.In my understanding this is a 3-way design with solely the subwoofer being ´blocked´,
that even significant phase distortion, like that introduced by an 8th-order crossover filter, isn’t noticeable to listeners.
Multiples of research showed that the most critical factor in determining overall preferred sound is how aligned direct sound and reflections are in tonality. Because dispersion characteristics play a big role in determining the sound of reflections, this alignment between direct and indirect sound requires controlled dispersion from low frequencies up to 20khz.
That's why modern speakers utilize very high order crossovers(allows the dispersion transition smoothly between drivers, the higher=the better to a point), multiples of waveguides, DSP to establish cardioid dispersion pattern etc.
This is the dispersion per frequency behavior evidence based community likes to see in 2025.
Simple as it should be, except for the price.View attachment 442878View attachment 442879
Marble speakers
Not sure if it's better than aluminum but still cool![]()
