I have a couple of questions and comments regarding this post:The posting you claimed was wrong specifically said current, not signal.
If there were no mobile electrons there would be no current flow. Both conductors and insulators are filled with electrons. But it is the mobility of electrons in the conductor that allows signal flow. If it were just an electric field that carried the signal, we could send it down a plastic rod.
The usual analogue is a hose full of marbles. If you push on the marble at one end of the hose another marble pops out of the other end. The marble velocity is very low compared to the velocity of the force pushing the marbles along the hose. But if the marbles didn't move at all, nothing would happen at the other end. So indeed, the actual speed of electrons is almost comically low. Snails pace. But their movement is an intrinsic part of an electrical circuit. In the marble filled hose the signal propagates at the speed of sound in glass (assuming glass marbles). In a wire the electron to electron force is mediated by the electromagnetic force, which moves at c.
Signal propagation is represented by Maxwell's equations. Which combine electrostatic and magnetic fields. Critically, you can't have a magnetic field without moving charge. Although the velocity of electrons in a conductor is really small, astoundingly, it is the combination of relativity and moving electrons that causes the magnetic component.
If you want to propagate an electromagnetic field without a wire, it works as the electrostatic and magnetic fields form a sort of mutual dance as they propagate. This is commonly called a radio wave. It is a different problem to what happens down a wire.
You might also consider how a chemical battery works. There most surely are moving electrons, as without them, the chemistry won't work.
1) What is the meaning of "velocity of the force?" Force is defined as the product of mass and acceleration. "Velocity of force" would imply that the force is moving in a particular direction at a rate of speed.
2) "...you can't have a magnetic field without moving charge." A fridge magnet proves this false unless "electromagnetic" field is what was intended.
3) "You might also consider how a chemical battery works. There most surely are moving electrons, as without them, the chemistry won't work." The electrons are only moving outside the battery. Inside the lead-acid battery, for example, it's hydrogen and bisulfate ions that are moving.
