Rayharrison
- Joined
- Jun 27, 2021
- Messages
- 2
- Likes
- 0
I recon see how you go. If it struggles then I don’t think you can go wrong if you amplify the LCR channels with a power amp and let the receiver power the surrounds as they aren’t constantly active like the fronts which the avr should handle easily. I have noticed the avr still gets pretty hot with any amps active so cooling might be a good option. It is said that the Denon 3600 and 3700 are basically the cheapest processors you can buy when in pre out mode. I eventually plan to run all 11 channels of seperate amps which is optimal if in reality if a little expensive.
