Chris Prosser
Hey @DonH56,
I broke out my Bitscope and actually used it in MSO mode trying to debug something I just built and I can strongly recommend against it . From my research it looks like the manufacturer has basically moved on to other things. Software (which wasn't great to begin with) hasn't been touched since 2015 and not a single blog post about the Scope part of their business since then either.
I'm fawning over the Picoscope 2206B, the 50Mhz MSO variety. It has much larger buffers and the MSO aspect. But it's definitely something I'll need to save up for and not just impulse purchase.
During my research I also came across the Link Instruments MSO 28. About 1/2 the cost of the picoscope.
Given how much I've hated the Bitscope software over the years I've had it, that will probably be the deciding factor for me. Luckily both can be used in demo mode with no hardware.
Both are only 8 bit ADC.
On the other hand, I should probably stop fantasizing about new test equipment and actually fix the problem on my board...
--chris
--chris
