There are no power conditioners in medical equipment plugs.
Maybe I'm misunderstanding you- I see no mention of power conditioning in your quoted text. It just describes what hospital-grade plugs are: plugs tested for connection reliability.
I think it is extremely unlikely that any medical device manufacturer would pay $350 for a power cord set. $15 maybe.
(I spent decades in the medical device industry). I actually have some medical grade IEC cord sets. They don't make things sound any better but they are rugged, well built, and kewl. I always look for gauges bigger than the usual 18/3 .
It would be amusing to ask him who his medical device customers are and how much he charges them. If any.
Edit: A very brief Amazon search reveals that nicely made clear molded hospital grade cordsets RETAIL for $12.24. Since margins on Amazon are probably less than they used to be I would think that a medical gear maker might pay as much as $5. There is an audiophile decorated Viborg for 27.90 a bargain at about half the price.
I just got a loaner of an APx555 B Series. Oddly, for a device with this kind of sensitivity, the power cord included was pretty standard IEC.
What!? Those cheapskates at AP didn't send you their cryogenically treated, five nines optional IEC cable? Without it, any measurements will have to be taken with a grain of salt I'm afraid.
Huh, Oz is different than here. Here, we take measurements with test leads
For now.Some people have too much money.
And there's a sucker born every minute.You know what they say about fools and their money.
One of these gadgets miniaturized to fit into a cordset. Some instrumentation has them built in either as in the photo below or in the power entry module. Either way it would have had the same effect on his little radio set. They keep out the hash caused by every dimmer, scr controller, switching power supply for LED and fluorescent lighting,, nearby. These things don't hurt anything and maybe good to have in your system. But you can't hear them unless you are very suggestible.View attachment 29612
This guy is blatantly lying! It is against the law to blatantly lie in advertising.
“Green dot receptacles are marked to designate they are Hospital Grade. Another designation of “Hospital Grade” or “Hosp. Grade” is printed on the back of the receptacle. First off, these receptacles must qualify for UL certifications that general use receptacles must also qualify for. Then, these receptacles must undergo a different series of tests to be labeled with a green dot.
One such test is for the strength of the connection. A receptacle is hung upside down with a pin inserted and a weight attached. The connection is supposed to remain intact without the pin popping out. The receptacle must also be durable enough to withstand crashing and crushing. Extra grounding reliability is also built in.”
That means our sound is randomly UPSIDE DOWN half the time?!?!?!?here is nothing in the National Electric code concerning whether the ground connection in a 120V outlet is to be above or below the hot and neutral connection.
Upside down means that the receptacle is rotated 180 degrees in the vertical plane. There is nothing in the National Electric code concerning whether the ground connection in a 120V outlet is to be above or below the hot and neutral connection. There is no upside down per the standard.
