So my problem is that I just want to have a moderate amount of additional bass.. Nothing too crazy just a bit. I obviously also want to have the best Audio quality possible.
The problem emerged as I just recently bought the modi 3+ DAC for my already aquired magni 3+ AMP & DT 990 PRO (250 Ohm). Previously I was driving the AMP via a PCI-E Soundcard (Devil HDX) - I know it's a bit weird..
So what I was thinking initially when I ordered the modi was, that there has to be program of some sorts - like the one that came with the soundcard where you can just easily tweak your bass etc. Then I started reading into the whole Audio topic and I just didn't find quite the answer that satisfied me - it was either buy a specific DAC/AMP for more bass or other headphones. I also didn't really find anything about a good software that just works and does great. This kind of makes little sense to me since I can't be the first one having that problem but despite that I just did not find anything after a couple hours of 'research'.
So is there any such software out there or is it just truly the headphones (despite I read about them being quite bass-heavy)? I also plan to upgrade to a DT 1990 PRO - maybe that just solves my Problem altogether? It will be a little while though until then so yeah... And I also really don't want to buy a new DAC/AMP - if it's not necessary - as I just don't have them that long yet...
Thanks for helping me out
