Moondrop Paradise, Amazing curves!
For me the most important point is "The spec".
Look at this:
"Diaphragm With Pure Silver Etched Circuit:-
Moondrop has featured new high-damping flexible composite material for the diaphragm. Para also features redesigned highly-elastic pure silver circuit etching on the diaphragm on a two-dimensional topological structure. Both these technologies and high-power magnetic architecture, thanks to the N52 Neodymium circuit designed with FEA(Finite Element Analysis), enable the Moondrop Para to have a high-sensitivity and low-impedance design. Users can enjoy its premium sound with basic devices as well."
Finally a pair of headphones using the turbo-encabulator technology!
Would my Topping DX5 (set on High Gain) be able to drive these at a reasonable level? I understand that the DX5 is current limited at 50 Ohm and lower.
If I would like to get optimal performance on these headphones (at a reasonable cost) would it be worth it to buy a Topping A90 or would a cheaper Topping device also suffice? I am assuming the DAC in the DX5 is pretty good and I won't need to upgrade my DAC also.
I don't have the DX5 but I have a SMSL C200, with a bit less power than the DX5.
With the SMSL C200 I don't need High Gain setting to listen to the PARA. With High Gain on, it's difficult for me to go over 50 (on 99) with the volume level.
I also have a A90 (among plenty of others) on my desktop because this is my favorite amp: no bs with a remote. Everything is natural: manual selectors and big volume knob. Of course it rules...
The new closed-back DD JOKER, on the other hand, seems to have got everything right. Fits me perfectly (even though it looks suspiciously similar to the VOID) and sounds great, and at less than half the price of the VOID.
I got this last week as well. It doesn't have a lot of energy in the bas region but has some extra in treble. Quite comfy and good for gaming I suppose but it's not exactly made for professsional monitoring
The Para (not Paradise) is a very good option for folks wanting that oh so illusive “planar HD600”. It’s certainly a lot cheaper than the MM-500.
I loved the sound quality, but I am getting tired of headphones that clock in at over 500 grams. Same reason I didn’t jive with the Audeze.
The question is; do you feel the added subbass makes up for the downgrade in comfort? I didn’t.
Btw a good headphone amp is advised. The sensitivity is in V not dB/mW.
I can understand why Moondrop (MOONDROP) chose to abbrieviate PARADISE to PARA, and COSMOPOLITAN to COSMO, to match the Chinese naming, but I wish Moondrop/MOONDROP would go easy on the all-caps.
I agree with you that no amount of spec improvements can out-balance discomfort. The sound quality may be superb, but if you have to pull off the cans (or pull out the IEMs) half-way through a symphony because of heat/pressure/pain, it does tend to spoil the enjoyment of the music. :(
It’s the same old story; upgrade part of the sound and you inadvertently downgrade something else.
I’ve heard a fair few supposed HD600/650 killers in my day, and apart from a better bass (subbass) response, I still prefer my Sennies.
The comfort is brilliant and I also prefer the mids and treble over something like the Para or the MM-500.
I wish newer headphone makes would focus more on the comfort aspect to this hobby. Nobody wants to wear a birdhouse.
Similarly..if I buy a Lamborghini for some wild road adventures, I am not expecting a sandpaper dildo as a seat.
I have tested these headphones yesterday with this signal chain:
Losless tracks in ableton live > SSL2 cranked to the max on it's monitor output (not headphone output) > Magni Heretic on it's highest 3rd gain setting.
On most (but not all) of the tracks I preferred how PARA sounded without EQ. I used AutoEQ presets from Oratory and Superreview. Only on modern punchy metal tracks EQ was required to add proper bass response and treble.
I tried to get the distortion out of the headphones by cranking certain frequencies, and I could not make them distort. When I boosted the 35Hz area to the maximum before digital clipping, I was able to turn the amp up so much that it was constantly going into the protection shutoff mode, yet distortion was nowhere to be heard.
I would buy this straight away if it weren't for comfort. Clamping force is very low, when I shook my head the headphones wanted to fall off. No matter how I finessed the very stiff yokes in every direction the headphones would not clamp. In addition to this the standard pads have a smaller rectangular cutout in the center which was touching my ears (and they are on a smaller side). Plus, the pads are very shallow, and even if I did press the cups into my face enough to get a somewhat good seal, my ears were touching the plates covering the drivers.
Weight was actually OK, the headband distributes it well. I listened to them for around 30 minutes and did not feel discomfort from weight, only from ears touching the insides of the HP.
Given how millable these are with EQ I was considering to maybe swap to some overly thick angled suede/veloud pads from dekoni for exmaple and just fix the FR with EQ, but it is a risky endeavour without trying first, given the pads shipped are another 100 USD on top of the headphone price.
