- Joined
- Oct 25, 2019
- Messages
- 12,491
- Likes
- 18,085
Best I can tell, to add another selling point/differentiator into the mix .So what's the reason to use these xMEMS driver? Do they have some magical properties?![]()
The technology looks cool, but you ask the right question: is there any actual benefit for audio?So what's the reason to use these xMEMS driver? Do they have some magical properties?![]()
The measurements are not finalized and depends on the sample rate used because of there being a digital crossover and two DACs, and because the digital signal is never resampled through all of these...$99, apparently.
But it works with the HiBy music app to select presets and such. This app is so awful that it literally doesn't scan my files. I literally cannot use it.
But, depending on the tuning, even without being able to use the app, I may buy them.
Edit: Terrible measurements.
View attachment 395308View attachment 395309
It looks like the OAE1 by Axel Grell. Same dip in the treble.
It may be interesting for people who love sets that are simultaneously harsh and muffled.
I just think that the abundance of mid-bass and lower mids will more than cover up for the 2.5k and 4 k peaks, avoiding harshness effect but making them muddy due to the lack in the higher region.I'm very sensible to ear-gain. If you look to the other two graphs, the low amount of bass and the elevated 2k to 4k region would probably make it sound harsh, at least for me.
I included the MP145 in the comparison remembering you liking them, the two peaks are not so much higher than MP145 but the bloat region is far more elevated.
But clearly these are just speculations.
shenzhenaudio.com
The Moondrop M4P MTM Passive Monitor speakers have really nice spin and distortion data. Interesting! 400 usd
MOONDROP M4P MTM Passive Monitor Speaker
shenzhenaudio.com: professional headphone, earphone, amplifier, dac, decoder, hifi player, cable supermarket. you will find good price here.shenzhenaudio.com
SPECIFICATIONS
Description: 2-Way 4inch MonitorSpeaker
Impedance: 4ohms
Weight: 6.2kg(13.66 lb)
Crossover Frequency: 1800Hz
Sensitivity: 85dB(2.83Vrms/1M)
Rated PowerInput: 75W
MaxPowerInput: 150W
FrequencyResponse: 60Hz-30000Hz(-3dB,IEC61094-4Type WS3)
Woofer: 2x4inch(87mm)Carbon Cone Woofer
Tweeter: 1xlinch(25mm)ALU Mag Dome Tweeter
Dimensions(HxDxW): 380mm*185mm*155mm(14.96 inch*7.28 inch*6.10 inch)
Color: Matte black, Matte white
Distortion data is meaningless if we don't know at what SPL it was measured.They look good, but that bass distortion is quite high. Compare them with the cheaper (600€ a pair) Elac Debut Reference DBR-62, which also measure quite good in terms of tuning and seem to have better bass.
Up to 10k, the Kadenz and especially the Kato will not sound worse but at least different than the Gate, mainly because of the style of the bass up to 300hz. Just like the Kadenz will sound noticeably different from the Kato. The differences you see on this graph are not as negligible as you might think. While it is possible to get used to all of these sound signatures, we are nerds here. I agree that this is not a question of better/worse though. Some might even prefer the sub-bass focus of the Gate.Gate are there just to remember why one should spend 9X more...
Worth the price difference or not,Do you think the differences between Kadenz and Kato are worth a new model? But ok, market laws require you to renew the offer every now and again... View attachment 401929
My question was indeed only between Kato and Kadenz, and I was genuinely curious about your opinions on how much their differences would justify the creation of a new "model" in the line, especially since Kadenz doesn't seem to address much the lack of smoothness in the higher region that you also point out.Up to 10k, the Kadenz and especially the Kato will not sound worse but at least different than the Gate, mainly because of the style of the bass up to 300hz. Just like the Kadenz will sound noticeably different from the Kato. The differences you see on this graph are not as negligible as you might think. While it is possible to get used to all of these sound signatures, we are nerds here. I agree that this is not a question of better/worse though. Some might even prefer the sub-bass focus of the Gate.
I agree that Gate will sound slightly different from the other 2, but again, precisely in the higher region Kadenz doesn't seem to me so much better as one would expect from a 9X priced iem these days and as one could be expecting as a real improvement from the "older generation" Kato.In the upper treble, I expect the Gate to do worse than the Gate/Kato in an at least noticeable way. I own the Gate and I can say that the upper treble quality sounds lower than on any other IEM I have heard, in a way which (likely) cannot be corrected with eartips. The "lack of smoothness" in the upper treble is more drastic than usually. This is an area cheap IEMs still tend to do worse, and you can also see it on the graph: The pattern above 10k does not follow a smooth curve like on the other IEMs, but it is more like a spike followed by another spike. This is not a big deal for most people, but as I said, we are nerds here.
Not saying that you need to buy the Kadenz because of this. I agree that the vast majority of the population does not need more than a budget priced Chi-Fi IEM. But people who post hundreds or thousands of posts in this forum will likely care about these small differences. Other aspects include build/comfort/looks/etc.
That's for sure, Kadenz also have three different nozzle for tuning and a new DSP type-c cable in bundle, so there are other reasons for them, but as I said above, I would expect some more fixing to the FR lacks of Kato.Worth the price difference or not,
Given that all have different nozzles length and different included tips I there's a potential to sound more different in-situ than the graphs suggest < 3kHz.
