- Joined
- Oct 25, 2019
- Messages
- 11,066
- Likes
- 14,700
You'd have to think (edit, no, it's) around -4.6 dB. (Was looking at Q values not gain. Doh!)Thanks crin. Whats you preamp setting there?
I guess figuratively, I wouldn't say no sweat but literally, no sweat should be near itWould the Chu's work well for sports? Do they still in the ear well? Can they handle sweat?
I'd say not. They have the fixed cable which I suspect is a weak point if active. But the shells are small enough to can tuck them into the curve of your ear more than larger iemBasically, what I'm asking in regards to sports, are the Chu's durable and able to withstand some abuse, and are they able to stay in the ears with a lot of movement?
I like them more than my NC400 for biking and jogging. They are so small that they create a lot less windnoise. So far I havent had any problems with them staying in my ears. As said the cable might be a weakspot though.Basically, what I'm asking in regards to sports, are the Chu's durable and able to withstand some abuse, and are they able to stay in the ears with a lot of movement?
That is hugely a subjective mather. They don't stay securely in my ears nearly as good as the B2D does.I'd say not. They have the fixed cable which I suspect is a weak point if active. But the shells are small enough to can tuck them into the curve of your ear more than larger iem
I wouldn't recommend any iem without actual hooks for exercise to be honest.That is hugely a subjective mather. They don't stay securely in my ears nearly as good as the B2D does.
It's not the absence of the hooks, but the shape, angle and length of the nozzle that's all wrong for me.I wouldn't recommend any iem without actual hooks for exercise to be honest.
Oh, I get that. I mean generally iem and bouncing around isn't a good mix for meIt's not the absence of the hooks, but the shape, angle and length of the nozzle that's all wrong for me.
Would you use your B2D for exercise and sports? I have the 7Hz Timeless, but I'm thinking of getting something a little cheaper for exercise and sports. I don't want to ruin the Timeless in short order.That is hugely a subjective mather. They don't stay securely in my ears nearly as good as the B2D does.
I can play VR games with the B2D and KZ DQ6. But no, I wouldn't use IEMs for anything more active than that.Oh, I get that. I mean generally iem and bouncing around isn't a good mix for me
Yes, if you really want to use IEMs for sports I would use something cheaper. For me the KZs fit me really secure. Many KZs are quite cheap.Would you use your B2D for exercise and sports? I have the 7Hz Timeless, but I'm thinking of getting something a little cheaper for exercise and sports. I don't want to ruin the Timeless in short order.
Do you like the KZs more than the CHUs? Both are similarly priced for cheap iems to use for sports.Yes, if you really want to use IEMs for sports I would use something cheaper. For me the KZs fit me really secure. Many KZs are quite cheap.
No, provided I can get the Chu to seal well, it sounds much better than the DQ6.Do you like the KZs more than the CHUs? Both are similarly priced for cheap iems to use for sports.
