georgehifi
- Joined
- Sep 30, 2019
- Messages
- 131
- Likes
- 27
Like I said I tried all three sizes, all had the same "slightly light" bass with all of the 3 x gel ear pieces.Even a slight break in seal though can significantly affect bass levels and I think this is where most of the perception of tip differences on bass come from, it is almost always back to a seal issue. Some tips are even designed with a textured surface, intended to slightly break seal, to slightly reduce bass levels. This sort of works but it's a pretty subtle effect, usually with IEMs it's either sealing or it isn't and you go from full bass or very near to no bass.
I have "maybe" a feeling they "could" be even harder (more current hungry) to drive than what's reviewed here, as my DAB source is up and over 75% volume to get the same volume as my IEM's that came with it, which were only at 50% and over. (making these less musical/enjoyable than the no name IEM's that came with it)
@amirm what source do you use when testing these, what sort of output stage (specs) does it use?
Pocket Portable Digital Radio (RR10) - Richter Audio
The Richter Pocket Portable Digital Radio (RR10) boasts a DAB+ & FM Tuner, large LCD Display, in-built speaker with headphones (included). Check it out....
Cheers George
