MOON Is launching its first ever loudspeaker, The MOON VOICE 22
Jukebox
Didn't saw this coming but it can be the start of a nice adventure in the speakers world.
Design features
2-way loudspeakers.
The tweeter has a 29mm dome textile membrane and a large surround designed to work without a typical front plate, and is integrated into a custom waveguide, permitting a wider frequency range and lower crossover frequency.
The 155mm woofer has a cast-aluminum basket and mineral-filled polypropylene membrane that allows for a detailed midrange and strong, extended bass.
The crossover features a dual-layer PCB designed with carefully selected, high-quality metallized polypropylene film capacitors for optimal sound quality and long-term reliability.
The enclosure employs a unique patent-pending technology called CGD (Curved Groove Damping) to control the panel resonances of the loudspeaker.
The Hover Base lends a visually striking appearance to the enclosure, which seems to gracefully float above the furniture. It ensures that the Voice 22 may be placed on virtually any surface without leaving a mark, while adding stability to the loudspeaker and guaranteeing sound integrity.
Specifications
Tweeter: 29mm soft dome with waveguide
Woofer: 155mm mineral-filled polypropylene cone
Sensitivity: 89dB/2.83V/1m
Nominal Impedance: 6Ω
Recommended Power: 50W – 150W
Frequency Response (±3dB): 55Hz – 24kHz
Frequency Range (-6dB): 45Hz – 30kHz
Crossover Frequency: 1.5kHz
Dimensions (W x H x D): 20cm x 35cm x 29cm
Weight: 10.5kg
Courtesy of Moon:
Courtesy of Soundstage:
voodooless
Netherlands
Are they ashamed of the product? For the fact that they want to sell a loudspeaker, there is frighteningly little speaker to see in the video :facepalm:
Jukebox
Jukebox
It only their first speaker; it's shy, give it some time :)
On the other hand the low crossover point is interesting; also pretty good sensitivity for the size.
voodooless
Netherlands
Looks like drivers are from SB Acoustics.
Jukebox
Jukebox
Was thinking the same; They are Moon branded
Jukebox
Jukebox
Not great, not terrible.
Some mismatch in the crossover region and sharp drop off-axis at 30 degree. Definitely can be improved.
I listen to them in an unfamiliar room and was not bad at all. At least they didn't went for the bright showroom sound.
