Tidal/Qobuz plugin?
Qobuz works extremely well with upnp and a control point. Obviously the whole usp of moode is that's it's free (as in speech) software so doesn't have proprietary add-ons such as tidal connect. Maybe one day tidal will ship a binary that end users can install (as with roon) at which point I'm sure Tim would consider a roon like integration.Tidal/Qobuz plugin?
Thank you very much for clarificationQobuz works extremely well with upnp and a control point. Obviously the whole usp of moode is that's it's free (as in speech) software so doesn't have proprietary add-ons such as tidal connect. Maybe one day tidal will ship a binary that end users can install (as with roon) at which point I'm sure Tim would consider a roon like integration.
Should say both tidal and qobuz can be played from bubbleupnp or mconnect to moodes upnp client. It's not as slick as the app UI but it gets the job done. Once I've selected music the last thing I want to do is sit there doom scrolling on a phone so it's suits me.
Hi,
moOde 9.0.4 is available in the Media Player OS section of the Raspberry Pi Imager or as a direct download at https://moodeaudio.org. Visit the Forum for more information https://moodeaudio.org/forum/showthread.php?tid=6688&pid=55911#pid55911
There's no direct update from 8.x to 9.x as the underlying OS got an update from bullseye to bookworm.Hey @Tim Curtis ,
I'm running v.8 on a DIY streamer, is there a way to do an "in-place" update to v.9? The check option under System doesn't catch any available updates. I'm trying to do the update over SSH and avoid a clean install as that would require quite some disassembly of the streamer to access the uSD card.
On the v.9.0.5 release page there's a command for an update patch but I get that's only used for updating the v.9.0.0 only, right?
Thanks!
@Tim Curtis, just out of curiosity, what makes the RPi5 a pretty fantastic platform? RPi5 needs more power and runs warmer compared to the RPi4s which I'm using, I do not understand what would make the RPi5 better suited...Yes, I remember that thread from last year.
It was quite interesting and from what I read it mostly worked. Maybe another dev will pick up the effort someday and figure out how to get everything working including CamillaDSP.
I can't imagine though how something like this could be supported out of our project. Just doing the dev, support and build tooling for moode on Raspberry Pi family and RaspiOS is very challenging.
Raspberry Pi and particularly the latest pi-5 is a pretty fantastic platform for audio but I'd still like to understand your interest in running moode on other hardware. Is it mainly for convenience or are there some technical advantages?
pi@moode:~ $ moodeutl -m
CPU: 1.5 GHz | Load: 1% / 47C | Memory: 9% used | Disk: 14% used / 24G free | PHP: 4 workers
Ha ha, my RPi 4B indeed had the same, so heat is no issue then....Warmer? Here's a temp snapshot from one of my 5's playing a radio station and processing via CamillaDSP. That temp varies between 45C and 47C all day long. Seems OK to me.
Code:pi@moode:~ $ moodeutl -m CPU: 1.5 GHz | Load: 1% / 47C | Memory: 9% used | Disk: 14% used / 24G free | PHP: 4 workers
Nice. I read some of the various thread chains and it looks like system MCLK is also available for boards. Did I get that right?
