moOde audio player for Raspberry Pi
Amazing progress. I installed the service from the tar file. Tried to run setup via SSH but since it doesn't have a GUI it wasn't able to authenticate. I copy pasted the auth link on my laptop browser and it tries to redirect to localhost:port running on the streamer. How do I get it to authenticate on Moode? If this can be done via the Moode UI it would be wonderful.
With moOde 10.3.4 all you need is the qbzd binary. It performs "qconnect.pairing" automatically, there is no need for the manual login/auth process.
If you did run the now obsolete installer from the maintainers repo it will prolly cause tons of breakage so best to start with fresh 10.3.4 image and then run the commands below.
Code:
# Download and install the experimental binary. Use release "2.0.2.moode49"
sudo bash -c '
RELEASE="2.0.2.moode49";
wget -q https://github.com/PhilipVinc/qbz/releases/download/qbzd-v$RELEASE/qbzd-$RELEASE-linux-aarch64.tar.gz -O qbzd-$RELEASE-linux-aarch64.tar.gz;
tar -xf qbzd-$RELEASE-linux-aarch64.tar.gz;
cp -f qbzd-$RELEASE-linux-aarch64/qbzd /usr/local/bin/'
# Print the version
qbzd --version
IMPORTANT!
Its all experimental at this point. Practice Volume Safety and make sure you have a downstream volume control set to a low level before connecting and playing.
Let me know how it goes :)
I had just installed the qobuz-connect-moode-20260910-231444.tar.gz from yesterday.
But trying a fresh install now as above.
I'm using Qobuz Connect now with Moode 10.3.4 and "qbzd-v2.0.2.moode49" binary.
The instructions above download binary, decompress it and place it in /usr/local/bin/.
Next, I manually turn Qobuz Connect on in Moode Renderer panel and open the Qobuz app.
I use Qobuz app speaker icon to select Moode RPi4/5 and play directly to the Raspberry PI.
I use several Qobuz playlists I have built to stream up to 700 tracks to Moode at once.
Nothing like it.
I use an RME ADI-2 DAC FS off Pi USB port and it controls volume. I set Qobuz Connect Renderer settings in Moode at 100% volume, but if you don't have downstream volume control DON'T DO THAT. :D
I have a ton of music on an attached Samsung Fit 256GB USB drive too but there's something about
loading 100's of tracks from my Qobuz playlists at once that's totally cool for unattended hours of listening.
Moode just keeps getting better and better!
Nothing like it.
Some info:
1. The Output device and Volume type that Qbz uses comes from the central Audio Config screen in moode but if Volume type != "Fixed (0dB)" then Qbz is configured for "Software" volume.
2. There is an "Initial volume" setting in the Qobuz Connect settings screen that applies if Qbz is using "Software" volume but it's still WIP. Sometimes it does not take effect on the Qobuz client app !!!
Here are some screen shots of the feature.
Config screens
Screenshot 2026-09-11 at 8.47.53 PM.png Screenshot 2026-09-11 at 8.48.16 PM.png Screenshot 2026-09-11 at 8.48.35 PM.png Screenshot 2026-09-11 at 8.48.43 PM.png
Example playback with sim external Touch 2 panel (1280 x 720).
Screenshot 2026-09-11 at 9.02.36 PM.png Screenshot 2026-09-11 at 9.03.14 PM.png
But no display or Browser is actually needed, just a client with the Qobuz app. The Qbz renderer is completely headless like Spotify Connect, AirPlay Receiver or the other renderers.
Code:
sudo bash -c '
# Print the version
qbzd --version
IMPORTANT!
After starting from a fresh image, it works now. I have volume as Fixed and yet the initial volume setting of 20% was still in effect, I had to bump it up to 100% and it's prefect now. Thanks!!!
That's what happen to me too. Inside the Qobuz Connect Renderer settings it was set to default at 20% so I could not hear anything until I figured out what was happening.
A 20% default volume setting works for someone with no down stream volume control, but if you have an external DAC with a volume control you may think nothing is playing until you change the Moode Qobuz Connect Renderer Volume setting to 100%.
Thats prolly a bug in qbzd.
When its set to use Fixed (0dB) volume it should output 0dB (100% volume) and ignore the app slider.
You can check the daemon settings using the command below.
Look for qconnect.volume_mode = locked which corresponds to Fixed (0dB).
Code:
pi@test:~ $ sudo qbzd settings show
audio.backend                     = alsa
audio.device                      = _audioout
audio.alsa_plugin                 = hw
audio.alsa_hardware_volume        = false
audio.alsa_mixer_device           = auto
audio.exclusive_mode              = false
audio.dac_passthrough             = false
audio.skip_sink_switch            = false
audio.dsd_mode                    = convert
audio.device_max_sample_rate      = none
audio.stream_first_track          = true
audio.stream_buffer_seconds       = 2
audio.streaming_only              = false
audio.memory_cache_mb             = auto
audio.volume_curve                = perceptual
audio.cache_to_disk               = false
audio.alsa_buffer_ms              = auto
audio.limit_quality_to_device     = false
audio.allow_quality_fallback      = true
audio.quality_fallback_behavior   = ask
audio.gapless_enabled             = true
audio.normalization_enabled       = false
audio.normalization_target_lufs   = -14
audio.pw_force_bitperfect         = false
audio.reserve_dac_while_running   = false
audio.sync_audio_on_startup       = false
playback.quality                  = hires_plus
playback.autoplay                 = continue
playback.persist_session          = false
playback.resume_playback_position = false
playback.show_context_icon        = true
playback.mpris                    = false
qconnect.device_name              = Test Qobuz
qconnect.startup_mode             = on
qconnect.volume_mode              = software
qconnect.initial_volume           = 10
qconnect.pairing                  = on
qconnect.pairing_port             = 8183
hooks.script                      = /var/local/www/commandw/qbzevent.sh
pi@test:~ $
Say, does anyone have an image of a 32-bit version of MoOde Audio still? Anything at 8.3.9 or earlier should do.
I've been running a 6.xx version smoothly for years on a first gen Pi Zero, wiped the SD card for something a few days ago, and was surprised the image is no longer on GitHub when looking to reinstall.
Tried piCorePlayer and Volumio, they are either not as streamlined or are significantly sluggish on a measly single core processor from over a decade ago.
Found a copy.
Can't find a way to expand SD card after install in the settings and kinda prefer the older UI for AirPlay on my previous install, but overall it works great!
