moOde audio player for Raspberry Pi
Hi,
I'm a moOde user (RPI4 - D50s DAC - 7" HDMI 1024x600 display e Nas storage). I updated moOde to version 9.4.2. I'd like to customize peppymeter by adding information about what I'm listening to to the skins (title, cover, duration, etc.). I saw that the "opt" folder also contains the skin folders and the meter.txt file, but it can't be edited. Do you think this will be possible via WEBUI in the future?
Thanks
Hi, for ease of support / feature requests tracking, you better post in the moOde's forum: https://moodeaudio.org/forum/index.php
Hi,
Thanks
Its not something for my TODO list but maybe another dev will take on the work.
Spotify changed their API so Spotify Connect isnt working right now (just endlessly skips through tracks), on moode 9.4.2
I think librespot is working on it
It seems that when pausing/unpausing on my Pi4/latest moOde/JCallyJ20MAX dongle/HD660S headphones/flac files on SD card there's a brief fade out/in respectively. Is this coming from the dongle or moOde itself? If it's the latter I don't see any way to disable is. Have i simply failed to find the option?
Oddly, when I power the Pi from a power adapter the fade in/out period contains what sounds like 50hz mains hum, like I have a ground loop, but at no other time using this or other dongle on various headphones and IEMs have I ever heard this hum. And when I power the PI from a powerbank there is no such hum. The hum volume is unaffected by the moOde volume. It happens regardless of whether the volume is controlled by hardware,software or camillaDSP. (I use camillaDSp for EQ with the volume set to hardware).
Maybe the USB device activates some power saving, the amp output goes HiZ and some noise voltage gets induced into headphone cable - maybe these headphones are very sensitive. It could be that when the 0V of the device is grounded (Pi power adapter) more voltage gets induced than when the 0V is floating against ground (powerbank supply).
Hi,
moOde 10.0.0 (Trixie) is available in the Media Player OS section of the Raspberry Pi Imager or as a direct download from the Release archive at https://moodeaudio.org. Visit the Forum for more information https://moodeaudio.org/forum/showthread.php?tid=8216&pid=67910#pid67910
I have a touchscreen that connects via USB C, or hdmi and usb. Is there any way to attach that to a raspberry pi and use it as a local GUI control for moOde
Yes, there's an option in moode Peripheral Config to display the WebUI or PeppyMeter on a locally attached display but beware that compatibility with the zillions of touchscreens out there is kind of a nightmare.
I personally use the M728 7" and M1012 10.1" HDMI screens from WiMaxIt (no longer in business) and they work perfectly. These screens are still being sold. Here's a link to the vendor I often use (B&H) https://www.bhphotovideo.com/c/product/1750309-REG/andycine_m1012_10_1_touchscreen_display_for.html
Thanks. I will give it a try.
Amazing. Worked first time. Downloaded an image of your new version and changed the config. Easy. Even the touchscreen functions properly.
I am getting a report in the system log of occasional undervoltage, but then this is connected to an old rpi 3, and the screen power comes from the USB.
Hi,
Tim,
1. I see the new RPI flasher version 1.9.6 only offers Moode version 10 now. It's a bit of time to REFLASH each SDcard as an in place update is not possible with version 10. Could you offer insight into how this new version fits into your future feature vision and perhaps security changes?
2. I notice after installing 10.0, if you push check for updates it gives an error message. Should that indicate no update is available instead?
Thank you!
Tim,
Thank you!
#2 - It should be "Software is up to date". I'll investigate.
#1 - Our project aligns with major OS releases of Debian/Raspbian which happen every two years or so. Here is the official announcement from Raspberry Pi Ltd. https://www.raspberrypi.com/news/trixie-the-new-version-of-raspberry-pi-os/
Scroll down a bit in that announcement and you will see the following statement:
"As with all major version upgrades, we do not recommend or support attempting to upgrade a running Bookworm image." ...
Thats been our approach for every new Raspbian OS release since way, way, way back to Jessie. Thankfully you can simply use the backup/restore feature in moode to carry all your settings and configs over to the new OS which lessens the pain :-)
Regarding the future, its essential for all our users that our project keeps up with upstream changes and security improvements in Raspbian OS and the Linux Kernel, and also all the 3rd party components for example AirPlay, Spotify Connect, Bluetooth etc.
So far we have been able to do that :-)
@amper42
Try "Check for update" again
1. Check update works now.
2. On Moode my three and four RPI4 units which I upgraded, I used the backup function. I found it was helpful but missed quite a few settings that needed to be set manually. Examples: a). Samba password needed to be reset. b). Turn on XSS detection. c). Turn on MPD autoplay. d). Reindex my USB drives and turn off radio and switch to albums. Should those setting be backed up and restored? Thank you!
Ok, lets go through these one by one
a). Samba password
It's a plain text password and so is not stored in the backup. It could be encrypted b4 backing up and decrypted during the restore but that was never implemented and is not on my TODO list but would be a nice project for another dev.
This looks like a bug. That setting is missing from the backup script. Added to TODO list to investigate.
I think you mean "Autoplay after start". This setting is in the backup script.
Check the startup log and look for:
"worker: Auto-play: on" followed by either of the two lines below.
"worker: Auto-play: using auto-shuffle"
"worker: Auto-play: using songid " A_SONG_ID
Library updating is always done manually via Menu > Update library.
This gives you control over when you start this potentially lengthy process.
e) Turn off radio and switch to albums.
After an update, the WebUI always starts in the main Playback view with the Welcome screen displayed.
There are two issues here - the fade in/out, and the earth hum during the fade in/out. I suspect you're correct and that it's a power saving mode in the dongle, causing the fading, and if that was sorted there wouldn't be a hum problem. I know of no way of configuring the J20MAX's sleep mode. The headphones aren't especially sensitive (Sennheiser HD660S). One solution would be for moOde to always play an inaudible but non-silent signal in to prevent devices from entering this mode. Another solution would be for moOde to add 0.5 seconds of silence before starting and after stopping so the fading takes place when there's no music. I'm not aware of any ability in moOde to trigger events on music start/stop/etc.
a). Samba password
It's not difficult to reset the settings that the backup function doesn't configure. But the user should not believe backup refresh will do everything. I still had to go through the four configuration panels and make sure everything was setup the way I like it. Plus, getting out of radio mode isn't as intuitive as I would like. I couldn't find the USB/album selection menu at first and had to start clicking everything to find it. Only after finally finding the hidden USB selection menu and reindexing was I able to find the album option. It would be great if USB/Album was one of the main menu options under Library like "folder" is. Why not make the Album view more obvious to find?
It's funny how after running Moode for 2 years and meticulously fixing all meta data to work properly with "Mp3tag" for Moode that it took me 10 minutes to find the USB/Album selection in the menus with a version 10.0 rebuild. I felt like I failed the IQ test. Reminds me of when I first started manually setting up my RME ADI-2 DAC FS before the ADI-2 App was available, which later made everything simple. Just saying, I think the ability to select the Moode USB/Album view after a complete rebuild should be easier in Moode 10.0.
Now that new updates will be a simple update in place with 10.0 it won't be an issue for awhile, but easy access to the USB/Album view might be something to consider? It's the absolute best visual interface for Moode and should not be hidden.
In fact, making Albums the default view instead of the radio panel would be my preference. But, if that's not to be, there should at least be a button right at the top of the Radio panel to switch to USB/Albums.
@threni: Maybe you can play with MPD option always_on . If it helps, the issue would be known and measures could be taken.
