There is an upcoming version of Moode which embeds Camilla DSP and I am very enthousiastic about it.
Now, you can run very easily a *.wav file on a cheap Raspberry 4 (it even works on Rasp3+Hat) and get a full room correction solution including EQ, FIR, IIR filters. Of course you have to do the room measurement and create the correction filters on a third part software like REW+rephase.
CamillaDSP is really user-friendly if you like headphones. You simply go on the site below and download the *.wav you need for your headphones with the proper bitrate.
AutoEq/results/innerfidelity/innerfidelity_harman_over-ear_2018/
Then, back to Moode 7.1 you select Configure/Camilla DSP.
In "General" select "Quick convolution filter" in the scrolling list
In "Convolution file", select "UPLOAD NEW" and the *.wav file
Unfortunately you will get an error message with two red crosses as Camilla only recognizes *.raw files. No worries, a CONVERT button has magically appeared. You press it and the Left and Right *.wav file are created.
In "Quick Convolution Filter" select the IR Left and IR Right in the scrolling list. Adjust the gain and that's it.
Eventually don't forget to SAVE
Hope it can help...
Hope it can help...
