Monoprice Monolith THX 887 Balance Headphone Amp: New Champ?
D
Deleted member 21726
Guest
Is Monolith truly balanced, from input to output? I'm between the SMSL SP200 and Monolith THX AAA-887.
SP200 is not truly balanced? XLR-inputs are converted internally to SE anyway?
Veri
SP200 is internally SE. 789/887 amps are real balanced at the output.
Labjr
I don't believe it's balanced input to output, as in pure balanced from input to output. Balanced input and balanced headphone output have two different purposes.
shinewu
This amp is right now on sale at monoprice for only $330 + tax. I think this is an amazing deal. I want to wait for the SMSL SP400 to come down in price. I think in terms of objective performance, they are very similar. But I like the looks of SP400. :)
Right now my headphones are Senn HD58X, AKG K712 and Hifiman Sundara, and I think none of them really need anything beyond the SE output from my SMSL M500. This is why I am waiting. But if I have real use of the extra clean power from THX, I will absolutely grab this amp.
I am unfortunately trying to spend $1k on a fancy tube amp this Thanksgiving. I know this is ASR, please be gentle to me. :)
rcstevensonaz
Just an FYI, for the 887 we upgraded over 50 internal components to increase performance:
5 Opamps – same opamps as 888 to reduce noise
32 Resistors – Upgraded to reduce noise
12 Capacitors – Upgraded to reduce distortion
Is AAA-887 a real THX specification? The THX AAA Features webpage only references THX AAA-788 ("stereo amplifier with power supply") and THX AAA-888 ("dual mono amplifier"). Based on various comments from MonolithGuy (quote above), JohnYang1997 ("Hpa4 has flying supply for the opa564 which lowers the distortion even further. 887 does not live to the performance of thx888"), and a few others in this thread ("uses THX technology, not THX certified"), I have the impression that this amp does not follow any THX reference design. So would it be correct to say "THX 887" is a Monoprice marketing term?
In which case, which of the following is a more correct statement about the Monolith THX 887:
  • THX 788 (stereo amp), but enhanced with characteristics to bring it close to AAA-888 sound quality?
  • THX 888 (dual mono), but missing some characteristics that would achieve full AAA-888 reference?
Thanks. My apology if this has been clarified elsewhere, but I've scoured a lot of sites and could not find a clear answer.
island_boy555
Bought an 887 and the new Geshelli Labs JNOG DAC on black friday.
How many watts per channel does the 887 provide @ 50 Ohms and 150 Ohms?
Also what do people mean by 'This amp isn't truly balanced?' I don't understand.. Balanced input from the DAC, balanced output to the headphones, what makes it not 'truly' balanced?
Veri
-I estimate around 0.8-1W 150 ohm balanced output, 3.7W 300 ohm balanced output (measured on page one).
-It uses a single ended volume pot and is converted back to balanced before the XLR 4-pin jack. Performance is still superb... wouldn't worry.
island_boy555
Thanks for the response, I think you might have mixed up your numbers, you said ~1W @ 150 Ohms and 3.7W @ 300 Ohms (balanced). Maybe you meant the other way around?
I read somehwere that these THX amps aren't 'truly balanced' but it makes no difference because the distortion levels are so low that you can't possibly hear it.. So I assume the only reason you'd use balanced vs SE other than out of necessity/convenience is for more power output.
I have a pair of Argon T50rp Mk3's that require (according to modhouse) at least 1W @ 50 Ohms. I've read people say the 887/789 is not enough since they're so inefficient, and others say it's more than capable. I'm hoping its the latter. Buying $400 amp and $250 DAC to drive a pair for $275 headphones is kinda silly, but it would be even sillier if the amp couldn't do the headphones justice.
My Argons are modded for balanced, but I don't have a balanced cable/adapter for them yet.. So I'm hoping it provides enough juice @ 50 Ohms SE that I won't have to rush and buy the balanced cable right away, I guess time will tell.
For anyone who may be wondering why I'd spend $400 (it was $325 on their website but they don't accept payment from my country's credit card) on the Monoprice vs the black friday 789 for $250, well I figured the extra 2 years of warranty is worth it. I find the 887 looks better, and I've read quite a few reviews about Drop having bad QC. Oh and the 888 looks very ugly to me, I read a lot of people complain about QC, channel imbalance, I didn't like the fact that the power supply is internal (as I live in the tropics and don't want anything hot on my desk). Not to mention the lack of a low gain stage for my IEMs.
I hope this amp (and the JNOG) really impresses me, so I can feel assured that I can buy some better cans in the future and not have to worry about upgrading any other hardware. When I have everything set up within the next few weeks (Covid really messed up customs here, takes ages to clear shipments) I'll definitely post a little write up with some pictures about my thoughts/experience with the 887.
Veri
I read somehwere that these THX amps are 'truly balanced' but it makes no difference because the distortion levels are so low that you can't possibly hear it.. So I assume the only reason you'd use balanced vs SE other than out of necessity/convenience is for more power output.
My bad :p early morning. When using balanced it'll have tons of power.. including for Argons. And yes, what you read elsewhere is correct :)
NOTE that if you use balanced inputs, gain III will clip at high volumes. Try to use only gain 1/2. It's in the manual ;)
island_boy555
Haha no worries! Yea I saw people talking about clipping earlier in the thread. Will definitely be wary of it if I need to use the 3rd gain stage with the Argons in balanced. Thanks for the reminder.
Pretty awesome to see I can get a response on a topic over a year old on this forum. I might end up enjoying my time on these boards!
Veri
It's a fun place.. unless you fear buying more and more things, which happens to the best of us, I recommend to stay and hang a bit :D
rcstevensonaz
It's a fun place... but the fear is real! Also, don't forget the hidden opportunity cost from reading through hundreds of pages on DACs and amplifiers.
I came over the past week looking for a good cheap DAC to connect a Bluesound Node 2i to; and I am walking away with an RME ADI-2 PRO FSR and a Monolith THX 887... and a Topping D90 that I no longer need after adding the ADI-2 PRO (but likely will keep anyway, you never know when you might need a DAC on a moment's notice).
I suggest you run as fast as you can from this so-called "fun place"... or, stick around and have fun while slowly becoming destitute :)
Cylphio
Palermo
Yeah I recognized people were going to interpret what I said the way you did, and respond in that way due to an ambiguity in what I wrote (my bad :). It is true that if you look at a particular measurement, you can demarcate within that measurement what can actually be heard by the human ear, and what can only be heard through a super sensitive machine. For example: looking at the master SINAD chart for DACs, the human ear might be able to hear the difference in SINAD (whatever that might actually mean to irl listening) between the Matrix Audio X-Sabre Pro and the NAD T758 AVR. But the human ear almost certainly cannot discern the difference between the SINAD of the Matrix Audio X-Sabre Pro and the Okto Research DAC8. However, the machine clearly can tell the difference between the Okto and the Matrix. This illustrates the point that you made, and I don't disagree with that.
In a different vein, my point was that most of the differences in sound that actually make a difference to people in irl listening do not have a specific measurement attached to them, and most likely will never be measurable. For instance, the dynamics, sound stage, and imaging of a particular headphone cannot have a measurement ascribed to them. In order to ever obtain what might look like a "measurement" of those things, you are getting into like hard AI territory, and at that point by nature any "measurements" that might be possible, will be colored by subjectivity. The biggest factor in a headphone based sound system that makes an actual audible difference during listening is the headphones themselves. You can't take a measurement or any group of measurements that will tell you whether the Focal Utopia is "better" than the Meze Empyrean, and make a chart out of it. Thus most of the differences between equipment that are actually discernible are immeasurable. Now that is not to say measurements are useless. Measurements are what keeps people from going out and spending 20K on a DAC, and thinking it sounds better than something like the RME-ADI2. The endeavor to measure the measurable stats of the most popular consumer amps and DACS is venerable and protective of the consumer. However, thinking that every fact about an audio system can be reduced to measurable facts is just flat out wrong, and I don't think there are too many people who believe in a pure reductionist model when talking about headphone systems (or any audio system).
How I like blind tests...
MediumRare
Chicago
How did you decide between the Bluesound Node and a Chromecast Audio?
Cylphio
Palermo
So, you guys convinced me and now my money went to Drop for the Drop/Grace Balanced SDAC (150 euro shipped and taxed) and to Monoprice.eu for the 887 (407 euro for the amp and 11 euro for their 0,40 m Xlr) to feed my hd600 with balanced cable. Questions:
- Will I be floored by the difference coming from the little FiiO BTR5 in balanced mode? Surely I don’t expect night and day differences, but I hope that the sense of grain and congestion I hear from the little dongle (which has a very big punch at 40 out of 60) will disappear once the beasts awakens...
- Can I connect the dac with both the connections and select them with the switch? Will the dac suffer from being used in this way?
- Is the dac audible noisy through the the 887 in balanced due to his inferior measurements?
- Is the sdac less noisy throug the unbalanced connections?
- Is the 887 ideal connection balanced using the gain in 1 and 2 position (I will not use the 3* at all) or, being the 887’s design less prone to accept the 4 volt, the unbal will fit better the input? And so: should I cancel the order of the sdac b in favour of a e30 or something similar?
- while I wait for the dac Can I connect the hp out of my MacBook into the unbal in? If yes, What volume should I choose?
can I use the monitor pre out of my Universal Audio Arrow to feed the balanced in of the 887? If yes, Is there any risk?
These are my doubts since I can cancel the order of the dac today. Thank you in advance for your extremely clear explanations you did before my post (Yes, I’ve read all the posts and studied the most difficult parts).
RickSanchez
Cartographer
Austin, TX
Possibly. I don't believe the Fiio BTR5 has been measured here so it's unclear what its performance is like However, some other Fiio portable devices haven't done well when measured by ASR:
As such it's possible there will be an audible improvement going to the Grace Balanced DAC.
You might want to ask that question on the Grace Balanced DAC thread.
No. The Grace is a completely competent DAC as demonstrated by the measurements.
No. It's actually the other way around: if you have ground loop issues with your setup you would want to avoid using the unbalanced connection and use the balanced interconnects.
Not sure what you're asking here. If you don't want to worry about anything I'd say just connect the Grace Balanced DAC to the 887 via XLR (balanced) interconnects. As for what gain setting you use, that will be up to you based on what headphones you have connected and how loud you want the volume.
Yes, you can connect directly as the hp out of your MacBook has its own DAC. As for volume (and gain): that's completely up to you.
The Grace Balanced DAC is a very capable DAC, just one that is stripped of features (e.g., display, remote control). You shouldn't worry about it working with the Monoprice 887.
Reactions: PSO
Veri
The clipping in the design is when using balanced inputs and Gain III, only. Balanced in, Gain II is still more powerful than single ended in Gain III though. So there is no worry here. Just don't make the amp clip trying to blast absurd volume levels and you're golden.
About the Fiio BTR5, if you are currently using it balanced it will likely sound very similar to the new set-up you're considering.
See https://www.l7audiolab.com/f/measurementreview-of-fiio-high-fidelity-bluetooth-amp-btr5/
Relatively high harmonic distortion, but especially balanced it's totally "fine".
Cylphio
Palermo
Thank you very much for the help. And What if I connect my audio interface (Universal Audio Arrow, weak hp amp) from the pre out to the 887? I have to match carefully the volume? My idea is to use these cables:
https://www.monoprice.eu/collection...able-16awg-gold-plated?variant=37546695262385
what's the difference between a pre balanced out with variable volume and a fixed 4 volt out? Will a certain volume make the two solutions interchangeable? This solution of course is intended as provisional and to be used until I choose a dac and it arrives.
