Ralf Stocker
- Joined
- Jan 22, 2019
- Messages
- 147
- Likes
- 90
Any photos from the inside?
Wow so slightly less noisy than even the Massdrop THX amp. My only concern was that you tested the previous THX amps at 5.8V output at high gain rather than 4V output on medium gain on this THX 887 amp (For historical reason, I am running high power headphone amps at 5.8 volts output using XLR input at 4 volts).
Is it a fair comparison this way?
Oh it's vs time! 0.8uV. Alright. Well done.I guess this is the background noise, if I understand the graph correctly:
Pic was grabbed from https://www.monoprice.com/product?p_id=39359 .
Don't worry. It won't be available until late October.WTF! My 789 just started shipping!
Can we get a spectrum of 4V into 32ohm? 0.5WIndeed. I am tired of recommending the Massdrop THX and then be told people can't get them. Maybe competition will also force them to increase volume.
My THX AAA 789 arrived today. It's a great amp. The difference between the Drop and the Monoprice it to small to be of any concern IMHO.
You can certainly use it as a preamp. And a more than capable one. Just you need to unplug your headphones.Only annoyance is that it can't be used as a preamp... The Benchmark is also preamp with balanced outputs. The JDS Atom is also a preamp but with single ended output.
True but you have to make/find some new cables/adapters... then unplug/plug cables every time you want to use your speaker system... that can become quickly a major annoyance.You can certainly use it as a preamp. And a more than capable one. Just you need to unplug your headphones.
I believe we can do even better, about -130db.119.. didn’t think we’d get that outside of the digital realm. Nice!
