I think I just remembered the answer to this. This only happens when you plug both in right? If you unplug any of the two it won't pop right?I recently acquired one of these 887 headphone amps and have been enjoying it immensely. I have noticed something peculiar, however, when my LCD-3’s are plugged into the balanced jack and my HD650’s are plugged into the single ended jack at the same time. Upon turning the amplifier on or off, there is an unpleasantly loud noise in both headphones that sounds like an electrical discharge of some sort. I wrote to Monoprice about this but have yet to receive a response, it being a weekend. Has anyone also encountered this issue?
The protection circuit iirc only opens the positive side of the amplifier output.
Let's first talk about two scenarios where only one headphone is plugged in.
Balanced: one v+ one v-. at startup v+ is open only negative side is connected to the v- hence the headphone is open so no pop.
Unbalanced: one v+ one gnd. at startup v+ is open so only gnd is connected so headphone is open so no pop.
These two scenarios, there should be no issues.
Now the issue comes in.
When both headphones plugged in, when start-up the pop will go from v- through both headphones in series and to gnd. Hence the pop.
