Monoprice Monolith 10, 12 and 15-inch Subwoofer Review
I'm also running dual 10s. They're great. I spent some time running REW measurements of the subs in about 45 locations in my smallish (13x13) room.
Sorted through that mess using the averager in REW to find the two best locations I could scrounge up. After running audyssey then manually adjusting delay settings. I got this:
Couldn't really hope for better in a square room. Very pleased with the performance of these subs. Hoping someday I see another pair of 10s up on classifieds somewhere so I can get 4 total to even out response across my 3 seats.
Just installed my 10" subwoofer. Playing a 20Hz test tone generates lots of port chaffing noise. Does anyone notice this noise on their monoliths?
Port chaffing noise is normal with high SPLs. I had two 10" and only in few occasions (Interstellar and Edge of tomorrow) where there are only bass scenes without any other sounds it could be heard. In every other occasions it's not hearable. It is only more engaging when bass scene comes and you can feel the airflow 3 meters from units. Like the real blast. Definitely 2,5D experience :cool:
Hello folks, I would like to give my 2c. I bought two 10" and after few days in my room I was impressed but want more headroom. So I returned it and at first opted for double 15" but they were too large to fit the room (damn what a shame) so I bought two 12".
I sit about 3 meters from subs in a room 26m^2 wide open to another 20m^2 room with 3,3m cealling height.
Here are the results after minidsp:
Blue - double 12" max spl with compression.
Purple - double 12" max spl before compression.
Yellow - double 10" max spl before compression.
Red/Green - Extended vs THX switch (low SPL)
Sub positions should be the same but not definitely sure (there has been few changes in the end for better seat to seat which is not much different to MLP).
I would like to also thank Erin for his immense effort to straightening up deformed audio realm.
Peace.
A lot of subwoofer feedback is in context of home theater, any feedback on how these are for audiophile listening, many people using these with their bookshelves etc?
They are excellent for music. Tactile response is great. I think Aron touches on this either in his video or a post somewhere. But for music you will be pleased.
Peace.
Hi Mate,
Great info.
Can you let us know how is the port chuffing on 12". Are yours V2 or V1? Can you hear chuffing on Interstellar and EOT as with 10"? Is it any better? Thanks
EDIT: Am I right that adding more subs would let them chuff less as they would have to work less for the same SPL? So when using 4 instead of 2 - would they chuff less loud or possibly not at all depending on SPL they are used at?
Hi Mate,
Great info.
As you already said: How much chuffing you get is dependant on the actual SPL. So 12" has less chuffing then 10" at the same SPL. But only in the beggining of EOT you can hear it (would say about 110dB at 3 meters). There wasn't any other movie where it was an issue. Also more subs means less SPL of each to get the same final SPL so less chuffing. I have v1, but I would say the performance would be the same.
When I have a spare time I will test it (only the 12").
Peace
Peace.
Those graphs are raw output - no EQ?
Hi everyone, I was searching why this sub is missing a ground wire while the manual clearly states it should have one.
No luck so far, I find it quite odd to be honest.
I started to look into it because I heard some bubbling like sound when sub had no input signal and was set to skip crossover. My guess was that some interference from the power cord got into my rca cables (shielded rca cables). I found that odd, but tried and solved this by using rca to xlr adapter and using xlr input on a sub and rca sub out on Wim amp pro. It worked, but I was left extremely confused why.
Sorry if this has been asked before, but I couldn’t find anything.
Does anyone know the sensitivity of the amp in the Monolith 10 THX Select, i.e. the max voltage before amp reaches full power?
Also, does the amp dsp protect the driver from over excursion in any way?
