...2 channel systems are so vintage.
The test starts at -120 dB and keeps increasing the level. The HTP-1 kept flashing its PCM indicator but would produce no output until we got down to -90 dB which is 1 bit short of 16 bit audio.
No need. It does not truncate the bits once unmuted.Hi Amir
Looks like there is some kind of muting active until you pass a certain signal level. Just like the good (?) old auto-on function in subs. I suspect you would get your full bit depth once the audio path is unmuted. Can you run your test starting from high to low levels instead of running it from low to high?
Vintage, yes, but still the easiest, most cost effective way to put together a musically satisfying system. I could probably walk in my local small audio dealer’s demo/ second hand floor with $1000 and walk out with an amp, a good pair of speakers and a decent turntable for that. And if one isn’t into vinyl there’s plenty of room left for a decent desktop DAC and a DYI RasPi based streamer. Or get a decent pair of headphones instead of the speakers, your choice.
Try doing that for multichannel.
It's a ground up different topology. Do you hear room reflection in nature from sound source? If the answer is yes then why bother hearing the original signal? It doesn't need the perfect phase to create center image, there is one actual speaker for that. So more channel = better in this sense. Also there's actual physical sound stage which is absent in dual channel. They are fundamentally different.I'd really like to see a room measurement from the mic position after one of the room eq's are run, of a 7.1+ system to determine how much cancellation is actually going on. Ergo, how much of the original signal reaches the listener's ears. I understand that the system attempts to set the delays on each output accordingly, but there must be a significant margin for error given how many additional reflective signals are created by all of those speakers.
Can you please explain that? I’m not entirely sure what you mean....
No, single channel is easier and cheaperVintage, yes, but still the easiest, most cost effective way
I can’t get no satisfaction ...from 2 channels anymore. 5.2 is the minimum requirement.a musically satisfying system
Sure thing. 5.2 goes well with ALL the recorded musical material in existence.I can’t get no satisfaction ...from 2 channels anymore. 5.2 is the minimum requirement.
Unless of course you're listening to any one of the more than 10 million music LPs recorded in 2 channel.I am not an engineer, so I can't expain it thorougly.
I do remember the manufacturers response in the XMC thread: it doesn't apply to real world signals, only in measurement situations.
We should keep in mind that this is not a 2 channel dac.
Its 16 channels, not two, + dsp-crossover functions+ expensive room eq software (7.1 Dirac software for PC used to cost 700 euros)+ HDMI-dolby-dts etc codecs/royalties etc etc.
I consider it a bargain, and definitely measures better than any AV product tested here. 10db better SINAD than the Marantz 8805, which is more expensive, 6 db better than the NAD (also more expensive).
Comparison with the 2 channel equipment is not easy. There are some 2 channel dac- processors with good Room eq software and subwoofer cross functions from NAD, minidsp, Lyngdorf, Trinnov, and they definitely cost a lot more than 1000 euros. For 2 channels. No codecs/royalties included.
Lets do the math.
And most important: I would never consider buying 2 channel processors in 2020. Multichannel reproduction is way more satisfying- and accurate (!) with the appropriate recordings.
I think the whole purpose of the additional speakers is to swamp the room related effects by creating direct sound sources in 16 different places (in the case of Dolby Atmos), so the room does not need to add the ambiance b/c the surround speakers already do.I'd really like to see a room measurement from the mic position after one of the room eq's are run, of a 7.1+ system to determine how much cancellation is actually going on. Ergo, how much of the original signal reaches the listener's ears. I understand that the system attempts to set the delays on each output accordingly, but there must be a significant margin for error given how many additional reflective signals are created by all of those speakers.
Well, the JBL SDP-55 might exist one day, who knows. Release seems like it keeps being pushed back. $6K is not an easy pill to swallow, either, but still a bargain compared to ridiculous Trinnov stuff.
Try a low level multitone to see whatever it really truncates the bits. Oh no need. 16bit can't output clean -90db sine. So it's not truncated, just a mute.
‘Designed by clowns…supervised by monkeys:’
ABOUT Monoprice
Established in 2002, we have built a stellar reputation for product excellence and customer service.
We offer over 7,000 high-quality, affordable electronics and accessories to professionals and consumers worldwide.
Our proven business model eliminates entire layers of markup within the supply chain, which allows us to sell premium products at a fraction of marketplace prices with incomparable speed and service.
