Monolith THX AAA Balanced Headphone Amplifier TROUBLESHOOTING Power Button
kefka
Running it through a Schiit Modius DAC ---> 2 analog balanced cables ---> Amp ---> balanced out ---> Headphones
Had this amp and given it many hours of use daily since April of 2023. Today it was working fine and I went to use it after a minute away from the desk and the "White light" power won't turn on. It turns red like its stuck in stand by mode. Almost like its not getting enough juice from the supply to trigger the full power? Tried all the usual things one would think to do. Has anyone had an issue with these before?
The only thing I can think is I was using them with 2 extended balanced cables like 12ft of extra cable to sit in bed and watch a movie earlier but it was fine until after I sat them down and picked it up again later. Also I have just rearranged my desk setup and it is sitting close to the window to the outside, although it is at least 66-70 in the room, the Amp did feel a bit cold when I started to trouble shoot it.
Is there anything else I can try? I am no expert and this is my first Headphone amp.
If anything what other Amps would you all recommend? Not trying to have to buy one every year so I don't think I'll be going with the same brand if I do.
For some reason I feel like sitting in bed with the extended daisy chain balanced cables on such a low power amp might have caused either the power supply to weaken over time (the light still comes on the pack so that seems maybe unlikely), or maybe somehow the static electricity from the bed back fed into the unit itself and caused some sort of power issue. The light still turns on it just stays red like its in stand-by mode.
Its made in America
Well, we have already seen how they make their products:
OTOH,
And could you please not play around with fonts so much?
I still suggest you to look through the THX AAA 789 amp main thread (you Monolith is the same device, just in a different casing), there are reports about similar issues. Perhaps you could find some useful answers.
There seems to be no way to reset the fonts after copy and paste. Its something with the forum.
I appreciate the links and I'll definitely look into them. Thank you for the advice.
