In SFM, the starting point is not established by applying common filters first, but after the seat-to-seat variation has first been minimized using individual sub EQ, delay, and attenuation. The common filters are applied afterwards. The algorithm, though it's patented, is described in detail in Todd Welti's 2006 AES article,
Low-Frequency Optimization Using Multiple Subwoofers (PDF).
In MSO (my software), it's all done at once within the same optimization. This helps ensure that any attempts to minimize seat-to-seat variation don't render the final frequency response too difficult to equalize properly using common EQ. Though DLBC is proprietary, they do reveal some information about its algorithm in some of their white papers. I describe some of that
here.
I was having trouble figuring out what you were trying to say in post 26. It might be helpful to refer to Figure 14.17 (b) and (c) in section 14.5.4 of Floyd Toole's book. In 14.17 (b), that is an odd-order mode (1st-order), so identical drive to identical subs against the two walls will result in mode cancellation. The two lobes have opposite signs, + and -. In figure 14.17 (c), that is an even-order mode (2nd-order). That means identical drive to identical subs against the two walls will result in mode boosting. The two lobes have the same signs (both +). That is also stated in that figure's accompanying text, where it says, "The second-order mode has been amplified because the subwoofers are in lobes having the same polarity." Because of this complexity, trying to come up with hard and fast rules about what happens to the overall response is harder than it seems. When seat-to-seat variation is of interest, that's harder yet.
