DVDdoug
- Joined
- May 27, 2021
- Messages
- 5,688
- Likes
- 8,341
Whatever you like!!! It's a "creative effect" for you enjoyment so there's no right or wrong way.Do I need to add a delay to the rears?...
...Should the rear speakers be calibrated to be lower in volume by 3-6dB?
...I'm not keeping-up with exactly what you're now doing but if you are doing the Halfler/matrix subtraction the results depend on the "difference information" in the stereo recording so every song will be different anyway... If left and right are identical (dual-mono) of course subtraction gives you nothing from the rear.
There is a potential advantage to delay - Phase of the acoustic waves depends on the wavelength, the speed of sound, and the distance, and any added delay. (High frequencies* have shorter wavelengths so more phase shift/difference than low frequencies.) So the relative front-rear phase gets "randomized".
* if you listen to a constant 5kHz tone the wavelength is 2.7 inches. If you move your head slightly you'll hear drastic loudness changes as the waves from the left & right speakers, and direct & reflected waves go in-and-out of phase. Of course, your left & right ears aren't in the same spot so that's added "weirdness". Luckily, we don't normally notice this with constantly-changing music! With bass you get similar effects but you have to move around the room more and it's more noticeable with music.
