Justin8888
- Joined
- Feb 18, 2026
- Messages
- 13
- Likes
- 2
Hi all,
So I am in the process of reworking my entire home office and looking to build a new audio system. For reference, my current system is an FX audio FX1002A and some micca RB42 using my PC DAC. Speakers are at the back corners of my 70" sit/stand desk. The room is a 12' x 7' sun room. Overall, the system is fine for what it is, but I would like to take it to the next level, including some improvements to usability, I/O, a proper headphone amp and DAC, NCx122MP or 252 amp, etc. Anyway...
So I was looking around on spinorama for a pair of bookshelf speakers under $1k for the pair. While looking at the Ascend Acoustics Sierra-1 v2 and realizing that they will be ridiculously large on my desk, I came across the HTM-200SE2. The price, measurements, and size caught my attention. Measurements are from Ascend, but from what Ive read they are committed to good technique. $368 for a pair seems like a steal for what you get here. The caveat is that you essentially need a sub to use these. At $368/pair, thats not a problem, and maybe even preferred.
Now these are marketed as "monitors" or mentioned as surrounds/centers. Should this give me pause when thinking about using them in a desktop setup for music enjoyment? Ive been reading up on ASR just long enough to know that sound is sound and any "color" is distortion and if I want to "color" the sound, I should do it through EQ and not just have the speakers do it by design. I am planning to go with a DAC/amp that has PEQ.
Ok, so if thats the case, why can I find almost no discussion about these speakers? I find it hard to believe I've cracked some kind of secret code to unlocking super clean sound for under $1k w/sub ($600 gets a pretty decent powered sub for a small room, something like an SB-1000 Pro). Am I missing something here? Is the lack of discussion simply because these are not mainstream enough? Any drawbacks to this setup I should be aware of? Any other recommendations that would be superior for the price?
www.ascendacoustics.com
HTM-200SE2 MINI-MONITOR PAIR
High Performance Compact Speaker New Klippel NFS optimized version! Utilizing high-resolution, 360-degree measurements from our Klippel NFS, we’ve completely re-engineered the beloved HTM-200SE, delivering significant improvements across every performance category. We’ve also updated the cabinet...
