Here are some measurements of the Monitor Audio Silver RX1 bookshelf speaker.
It was released in 2010 and discontinued in 2014. The MSRP was $675 / pair.
It's a very nice looking speaker, with real wood veneer and excellent build quality.
My measurements are quasi-anechoic, with near-field port+woofer, corrected for baffle edge diffraction and combined with gated measurements at 1m distance.
The only measurement I could find online was from Sound & Vision.
www.soundandvision.com
They are using heavy smoothing, but the overall response is quite similar to my measurement:
Anyway, here's the results:
Directivity error at crossover.
Horizontal directivity:
0-90 deg:
0-90 deg, for comparison with Stereophile measurements:
RX6 looks very similar (measured by John Atkinson):
www.stereophile.com
Vertical directivity:
On-axis response:
Near-field:
Distortion:
Looks good except for the (resonance?) peak at 2 kHz.
The bolt at the back of the speaker was tight (holding the bass/midrange driver), and there were no audible issues during the sweep.
It also matches the Silver 100 measurements by Amir:
www.audiosciencereview.com
The peak remains when measuring at just 76 dB / 1m (86.5 dB @ 30 cm):
The estimated in-room response is a very good indication of how this speaker sounds.
The steep slope makes it sound a bit laid back, but the treble is still a little bright. The midrange dip is also audible, and actually makes some bad recordings sound less offensive (and it of course makes good recordings sound a bit hollow). The bass is ok in a small room, when placed close to the rear wall, but it really needs a subwoofer in a large living room.
I have listened to this speaker for several hours, and I still can't make up my mind whether I like it or not. It's certainly not bad, but compared to neutral speakers, there's just something missing.
Someone mentioned Monitor Audio speakers having a "scottish scccch" sound in another thread, and it's funny, because it's true. I don't know if it's the resonance/distortion peak, or just the tonal balance.
Monitor Audio Silver RX8 Speaker System HT Labs Measures
HT Labs Measures L/R Sensitivity: 90.5 dB from 500 Hz to 2 kHz Center Sensitivity: 90 dB from 500 Hz to 2 kHz Surround Sensitivity: 88 dB from 500 Hz to 2 kHz
0-90 deg:
Monitor Audio Silver RX6 loudspeaker Measurements | Stereophile.com
Sidebar 3: Measurements I used DRA Labs' MLSSA system and a calibrated DPA 4006 microphone to measure the Monitor Audio Silver RX6's frequency response in the farfield, and an Earthworks QTC-40 for the nearfield responses. The Silver RX6 is specified as having a voltage sensitivity of 90dB/W/m...
On-axis response:
Near-field:
Distortion:
Monitor Audio Silver 100 Review (Speaker)
This is a review and detailed measurements of the Monitor Audio Silver 100 bookshelf speaker. It is on kind loan from a member and was just discontinued. It still sells for $799. As you see, the Silver 100 is a very attractive speaker. It feels substantial compared to more budget speakers...
