Monitor Audio PL100-3G 'nominal impedance' vs 'minimum impedance'
There are no musical recordings with 30 dB musical peaks!
I have a Rite of Spring that doesn't comply with your edict.
-40dB during the 5 minute segment marked, with some headbanging by the bass drum(s) elsewhere.
Redwood Symphony:
Drumbling example:
We don’t disagree on this but you have to use peak dynamics to account for the peak power needed from the amplifier:
How Much Amplifier Power Do I Need?
This is why using DR numbers from the loudness database is not useful as those numbers are not peak numbers.
Quote from your link: "For example, if you need 100 watts continuous power to achieve the desired average SPL, you need 1,000 watts continuous to handle 10 dB peaks, 3,162 watts to handle 15 dB peaks,..."
So, for 15 dB peaks over average SPL we need 31,62 times more power. OK.
Now quote from my post #18:
Average loud SPL at the listening position is about 80-86 dB. For the calculation let choose 83 dB value. If listener is at 3m distance from the loudspeaker, than loudspeaker must deliver SPL=92.5 dB/1m (83+9.5). Two loudspeakers (as in stereo) in the room can deliver more, but let keep calculation simple. Sensitivity of PL100 is 85 dB/2.83/1m (82dB/1W/1m), so to achieve average SPL=92.5dB/3m it needs 11.2 W of amplifier power.
Maximum 400 W power from M23 allows clean 15.5 dB peaks from the average 11.2 W.
For average SPL = 92.5 dB/1m it needs average 11.2 W.
11.2W x 31.62 = 354 W needed for clean 15 dB peaks. Or as I wrote: "400 W allows clean 15.5 dB peaks".
Q.E.D.
Edit:
Another quote from your link:
"The recommended power allows for signal peaks of 10 dB for folk, jazz and pop music. Actually the peaks might be as high as 25 dB, but we're allowing for some inaudible short-term clipping.
In compiling this list, we made the following assumptions:
  • Typical loudspeaker sensitivity is 85 dB SPL/W/m for home stereos,
Total amplifier power required in various applications​
  • Nearfield monitoring: 25 W for 85 dB SPL average (with 15 dB peaks), 250 W for 95 dB SPL average (with 15 dB peaks)
  • Home stereo: 150 W for 85 dB SPL average (with 15 dB peaks), 1,500 W for 95 dB SPL average (with 15 dB peaks)"
Which is what I said, that your amp will be clipping if you don’t account for the peaks! If you chose to allow clipping, that is your choice.
Right, we agree on this. I already said this. You are still confused because you stated this:
I have this versions of Rite of Spring, with max DR=21, which comply to my edict:
Max DR is not peak. It is telling you which track as the highest average DR on the album. The DR value then averages out over all the tracks. The loudness database does not give you peak DR information.
Over and out….
It will not clip, even with 15.5 dB peaks:
Q.E.D.
I am tired of repeating this simple calculation. If Crown is satisfied with 15 dB peaks for nearfield monitoring and home use, then it is good enough for all others.
The DR value is in use in broadcasting, to prevent clipping in the whole audio chain, including preventing clipping of amplifiers.
Over and out.
c.f. A Beginner's Guide to Dynamic Range in Audio Production
As shown, the Dynamic Range (DR) is the difference between quietest and loudest audio signal levels [e.g. measured in dB] -- regardless of how much amplification one ultimately applies to that audio signal.
Every 10 dB increase of DR draws 10x the amplifier power. If the recording has a DR of 30 dB and one is listening to the quietest audio signal at a modest 0.7W, then that recording's loudest audio signal will require 0.7W x (10 x 10 x 10) = 700W.
Yes, but for how long?
So much vim, vigor, and vitriol ;) goes into "discussions" of this topic. :facepalm:
I'll -- ahem -- just note (yet again), that the power arithmetic becomes much less frightening if one simply makes one's loudspeakers, say, 20 dB more sensitive than the current crop -- which hover, distressingly, in the low to mid 80s (and are sometimes also hard to drive, besides).
That's the way we roll at my house. :cool:
In the neighborhood of 102 dB per watt at 1 meter.
EDIT: For a bit of historical context, I'll add that the acoustic suspension craze of the 1960s and 70s, begun by Villchur & colleagues in the late 1950s, was greatly enabled by (and certainly "democratized" by) the availability of cheap, high-powered (by the standards of the day) solid state amplification.
Whether that was a good thing or a bad thing is a matter of debate. ;)
Which is not what is measured at sites like the loudness database. Depending on the tool, those measurements will either be based on PLR or PSR. The site tells you which algorithm is being used for each album - none of which are the above.
Agreed, but neither PLR nor PSR algorithms would measure more than the delta of the recording's (raw) quietest and loudest audio signal levels.
@epping4est I know this is an "old" thread and you already bought the M23. I just want to share my experience regarding amplification with my PL300 3G.
BTW: John Atkinson reports that the PL 300 3G EPR impedance can be as low as 1.9 ohms! so they need an amp capable of delivering high current levels at those transients.
NAD's M23 is a fine amplifier (I have heard it) but what the MA PL 3G range needs is an amp with very high slew rates in order to control the force of the big neodinium magnets on those high end drivers and the M23 doesn't provide that control level.
I could run my 300s to unhealty SPL levels with just a Benchmark AHB2 amp in stereo but I noted a huge improvement when I tested them with a Hegel H20 power amp. Not because the amp has more power (My measured SPL at my listening position are about 65-70 dB and that is more than enough volume level for me) but because the amp has very special transistors with big slew rates that can take a firm hand on the Platinum drivers. The control and precision delivered with that amp to me at this time has been unmatched and transform the speakers from very good sound to amazing level.
Try it if you have the chance!
I'm having a hard time understanding how an amp with "very high slew rates" is needed "in order to control the force of the big neodinium magnets."
Driver control on an amp is generally attributed to damping factor (output impedance), not slew rate.
I'm also having a hard time understanding how Hegel has "very special transistors with big slew rates." What transistors are they, and what makes them special in terms of slew rate? And how does that slew rate allow the amp to "take a firm hand on the Platinum drivers?"
Can you elaborate on what you mean?
And when you compared amps (Benchmark vs Hegel) did you do it level-matched and blinded?
It sounds better, you can hear immediately that the drivers get much more control and precision on the raises and decays. It is not hard to identify actually, you can hear it almost instantly. When I purchased that amp I benchmarked it with several others including a Hypex nCore Class D and my Benchmark AHB2 and was also tested not only by me I was with two other seasoned audiophiles. The improvement on that speaker with that amp over all others was very noticeable for all of us.
A fast slew rate helps the driver to follow the signal timming much more accurately. Hegel doesn't reveal the transistor brand and model they use (I am not opening my amp to answer that for you as it is still under warranty) but they declare that are hand matched bipolars and the brand that makes them stopped production because they where expensive to make so they bought all the remaining inventory. They are actually very proud of using them (google their interviews).
I want to make clear that this improvement is only on the power amps and not the integrated amps they sell. I tested both their higher end integrated (the H390 and the H600). The H390 and H600 are fine amps but not near performs what the power amps H20 and H30A do. The differences are very noticeable even against the H600 that is actually a very expensive piece. I actually considered buying H600 before demoing it to simplify my chain but there was no contest sound wise against the separates. The store even allowed me to bring the showroom amps home to test them side by side with the ones I had.
