epping4est
- Joined
- Nov 27, 2024
- Messages
- 31
- Likes
- 7
- Thread Starter
- #21
I agree, "It does not work that way.", but I'm confident that the M23 can deal with the PL100-3G's 4-ohm dips. There's a lot of music within those 4-ohm dips, but also a lot of music outside those dips. [My original concern was that the PL100-3G's 'nominal' impedance could fall below 4 ohms.]
An alternative to bridging the M23 is to bi-amp the M23 -- e.g. Plan-B. The PL100-3G's crossover point is 2850Hz -- i.e. not identical to the 1G's. The impedance curve above 2850Hz will be pretty much 10 ohms or more. So if horizontal bi-amping, then the HF M23 would see mostly 10 ohms while the LF M23 would see mostly 4 ohms -- 175W at the HF and 400W at the LF. Might sound fine, but might not. I intend to try all options.
