epping4est
- Joined
- Nov 27, 2024
- Messages
- 31
- Likes
- 7
Here [link], at the bottom of the web page, are Monitor Audio's specifications for the PL100-3G loudspeaker. The 'nominal impedance' [aka average impedance] is 4 ohms, but the 'minimum impedance' is also 4 ohms. AFAIK a speaker's average and minimum impedances can be equal only when the speaker is a resistor -- i.e. one or both specifications are incorrect.
I have read the comment that manufacturers' specified 'nominal impedances' are generally meaningless, but I really need the truth about these speakers ...
I am considering whether to drive a pair of MA PL100-3Gs with a pair of bridged NAD M23 amplifiers; however, [the M23's User Manual says that] a bridged NAD M23 amplifier is rated exclusively for 8 ohm loads [with e.g. 4 ohm loads expressly discouraged]:
How can I be certain that a MA PL100-3G would [not] present a problem for a bridged NAD M23? e.g. If I can establish that the PL100-3G typically operates well above 4 ohms, then perhaps a bridged M23 would be fine with that.
