Hey all,
I am having consultations with home theater installers to set up a in-wall dolby atmos system and my first installer works with Monitor Audio components. I tried doing some internet sleuthing to get Spin data on the components to help me decide but no luck. The closest I found was this set of Monitor audio floorstanding speaker data from sound stage network. https://www.soundstagenetwork.com/index.php?option=com_content&view=article&id=16&Itemid=18
It looks like they have smooth response but some strange distortion around the crossover region which gives me some pause.
Have any of you come across spinorama data for these options or otherwise have some previous experience or advice on Monitor Audio?
He's proposing two options. The "Platinum Series" or the "Silver Series." And he recommends keeping all in the same series to keep the tweeters matched. And we'd do the same speaker for the L, C, R depending on my choice. The platinum series looks like it is a Ribbon tweeter and I haven't seen much spinorama data on these to see how smooth they are.
Amir's review of the Revel was underwhelming and the Monoprice Monolith was positive so not a lot of in-wall spin data to get a sense of the performance.
Any feedback or advice on these speakers and competing choices would be welcome. Thanks!
Front channel platinum and silver
https://www.monitoraudio.com/en/product-ranges/controlled-performance/cp-iw460x/
https://www.monitoraudio.com/en/product-ranges/controlled-performance/cp-iw260x/
Side and back channel options platinum and silver
https://www.monitoraudio.com/en/product-ranges/super-slim/wss430/
https://www.monitoraudio.com/en/product-ranges/super-slim/wss230/
Atmos options
https://www.monitoraudio.com/en/product-ranges/platinum-ii/platinum-plic-ii/
https://www.monitoraudio.com/en/product-ranges/core/c380-fx/
https://www.monitoraudio.com/en/product-ranges/controlled-performance/cp-ct380idc/
Atmos options
