Monitor Audio Bronze 50 6g with Silver 250c Center.
Syyron
Hello, i got a question would it be fine to use the monitor audio bronze 50 6g Left+Right , with the monitor audio silver c250 Center or would i notice any imbalances/timbre?
i heard u should not cheap out on the center channel and since this is one of the few 3 way center channels out there im tempted to get the c250 Center instead of the Bronze 2 way.
i could get the Bronze 50 6g for around 350 Euro, the Silvers 50 7g would be 600 Euro (open box)
what would u recommend? should i match L C R with the same line or do u think this will work just fine?
I’m going to say to get the matching one and you will have the proper piece to join the other speakers that are designed for a reason
