MattHooper
- Joined
- Jan 27, 2019
- Messages
- 11,193
- Likes
- 19,892
Interesting. If it is, I don’t know if I’m digging the design. And it certainly looks like a very niche product.
Looks like a crossover of Cadentia 3 and Sourcepoint 10![]()
Yes, either 'bespoke' cabinets (unfamiliar ones to me) -- or AI. Unfortunately, AI is always an option.Ah, right. If I brighten the image and zoom in it looks pretty much like this driver:
So I’m guessing that speaker was probably home made where somebody just incorporated that driver into those cabinets?
(and the speakers in the photo have casters on the bottom, which speaks more to DIY).
I wouldn’t imagine AJ would simply use those old drivers in his new design.
-- yes, I do have a pair of 604B Duplexes (as well as a pair of 604E). They're in reasonable condition functionally, but not nearly as gorgeous at those in @MattHooper's photo. Yes, either 'bespoke' cabinets (unfamiliar ones to me) -- or AI. Unfortunately, AI is always an option.
As an aside, the image @MattHooper posted above is a truly lovely pair of either original Altec 604 (unsuffixed) or 604B Duplexes -- probably the latter.
The 604 and 604B differ from later variants in the design of the treble horn. In those two versions, the horn is a true, albeit rather miniaturized, multisectoral horn. Starting with the 604C and at least up to the fairly modern (it's all relative) 604-8G, the horn was a) physically smaller and b) not multisector along its entire length.
As a further aside, the original 604 dates to ca. 1943 and the 604B toat least the very early 1950s1949.
source: https://lansingheritage.org/html/altec/catalogs/1943.htm
source: https://lansingheritage.org/html/altec/catalogs/1949.htm
As a further and even less worthwhile aside-- yes, I do have a pair of 604B Duplexes (as well as a pair of 604E). They're in reasonable condition functionally, but not nearly as gorgeous at those in @MattHooper's photo.
Yet not as good looking as either.Looks like a crossover of Cadentia 3 and Sourcepoint 10![]()
More reminiscent of TAD tbh, like their shorter, rounder sibling.Looks like a crossover of Cadentia 3 and Sourcepoint 10![]()
It’s a very unique feature, no?Interesting.
What is the relevance of AJ pointing out it uses concentric field coils?
I did a quick google and it is an old technology used before permanent magnets were readily available at sufficient strength.I don’t know. I don’t know enough about speaker design to understand the relevance or implications of field coils . That’s why I’m asking about it.
I need to dig more but it looks like only purveyors of snake oil are using the technology nowadays.
The cynic in me wonders if AJ is using his deservedly excellent reputation to create a hype around an old technology, applied in a novel way (concentric) to appeal to some audiophiles searching for what they’ve been missing all their life.
Will be interesting to see what the data says and what AJ says are the performance benefits.
www.audiosciencereview.com
Makes sense. Valid design choice.I noticed that Andrew likes to cross 3 way design very low,for example mine first edition F5 are crossed at 100hz.
This one 130hz.
I personally think it's because he wants to keep that important frequency range where voices and all the fundamental tones reside,in same time domein free from any crossovers and all bad things that carries with it like change of polarity, possible dips in the frequency response,....
Also when I listen to mine It seems like all the tones are coming from the middle driver's like proper point source.
I would like what do you guys think?
Yes I don't have these speakers, but I have a pretty cheap 3 way design tuned-voiced buy his taste and when I listen to "You what it darker", well i won't say any audiophile bullshit, but I'm getting tingles.I've always been a sucker for big, brawny tower speakers. I kept my Legacy Audio Signature II towers for about 20 years. They had their problems, but they did have that big, open sound, as well as powerful deep male vocals from singers like Leonard Cohen.
There is a school of thought that crossing over to the woofer should occur between 300 and 600hz to avoid the mid woofer playing down into the power powerband where many (not all) mid woofers can get uncomfortable, ie KEF. Just a note..I noticed that Andrew likes to cross 3 way design very low,for example mine first edition F5 are crossed at 100hz.
This one 130hz.
c'mon by! We'll leave the light on for ya.I’ve still never heard any of the Altec driver speakers. i’d really love to.
