- Joined
- May 31, 2020
- Messages
- 837
- Likes
- 1,487
Imagine these 888 in an 888A version, active and closed.
Wow.
Dreaming further: two eights in the back for cardioid.
Wow.
That's why the A10 uses DSP to give you a full bass response as much as capable from a small woofer anywayPorts offer significant bass advantages. Seal the port on any well designed floor standing speaker and you will hear an immediate reduction in bass. Most towers and subs come with port plugs but after listening to a sealed box the plug always comes out on my speakers.![]()
Mobile Topic I guessJust love how half the posts in a thread about the 888 are about Revel speakers
Once someone invests in something or covets it, it is difficult to believe that something similar is better. That's true for all major purchases. The data on sound speaks for itself. As far as looks that is subjective and in the eyes of the beholder. I would say one could live with many good testing tower speakers. Now that I have DSP my Theil speakers sound good enough to focus on finding new music but I am tempted by the SP 888's.Just love how half the posts in a thread about the 888 are about Revel speakers
Yes, you are correct. Front port versus Rear port can make a difference.
Front-ported speakers typically allow for more flexible placement. They can be positioned closer to walls without significantly affecting sound quality. Rear-ported speakers typically require space between the rear of the speaker and the wall behind them for optimal placement to maximize bass.
In addition, Rear-ported speakers are more likely to interact with room boundaries, potentially leading to a boost or dip in certain frequencies depending on placement. This could be an advantage or a disadvantage, depending on the specific room and setup.
Rear ports being physically closer to the rear wall is probably why people have the notion that they "need more breathing space" because on average they get more reinforcement due to thatI think this is somewhat of a myth. A port is usually tuned so low that the output is pretty much omni - and the response doesn't change much if you're close or somewhat further from the wall beyond what happens with any other speaker configuration.
I wouldn't rely on the Munich's impressions,the room was a constant happy hour.I listened to these speakers for awhile at Munich HighEnd and in my opinion they sound really, really good. There was one strange characteristic that stood out to me, and this might be due to the physical size of the speaker and position of the coax WRT one's head when seated: the soundstage always seemed to be coming from "down below" as if one was in a balcony and the performance was actually taking place on the level below. It didn't seem to depend on the source material. It was a bit strange.
The only basis I could think of for this sound signature is that one is always off axis from the coax itself. This is probably very much intended by AJ since coax drivers and horns can sound a bit honky when listening directly on their axis, and this goes away at about 15 degrees off axis. By positioning the coax driver below the listening height the listener is always off axis no matter what lateral position he/she takes. The off-axis positioning probably slightly accentuates the 500-1.5k Hz range and recesses the level above 1.5k Hz a bit due to how the speaker response changes as you move off axis from the coax (Erin measured it with the on-axis position being on the coax axis).
I wonder if this signature would go away if the speaker could be elevated by 20cm/8" to put the coax more at "ear level" when seated?
Did anyone else get this impression when listening to the speaker?
The room was relatively calm and quiet when I was there... Not really sure when you experienced "happy hour".I wouldn't rely on the Munich's impressions,the room was a constant happy hour.
What was evident though is their dynamic character,despite the punishing conditions there.
I'm sitting in a chair at my computer. The listening chairs were similarly upright, and I measure the height to my ear at about 46 inches above the floor. The speaker dims report the height as 42 inches, and using some guesstimation based on the pic of the speaker I think the coax center is more like 34" above the floor. So 12 inches / 30cm below the ear height. Unless you are slumped into a soft couch or chair, you are above the coax axis.Isn't the center of the coax around 36" off the ground, which is pretty close to average ear height when seated?
Sunday,about noon.The room was relatively calm and quiet when I was there... Not really sure when you experienced "happy hour".
An animated gif of the ASR Revel F328Be (rear port) and F228Be (front port) measurements locking the point of each 100Hz Woofer measurement in the animation shows port energy differences between the two designs. The F228Be front (orange) port design displays extra energy in the 50Hz to 200Hz range. Both enclosures have the same drivers while the F328Be has three 8" woofers and F228Be has two 8". The extra thump of the F228Be front port is audible. Port location can offer a measurable difference.
The speaker definitely has many positives and I am only guessing about why I might have perceived the sound stage to be "down/below". It was definitely something I noticed, but it wasn't offensive. I thought I would mention it since measurements would not capture that sort of thing.
www.audiosciencereview.com
