This is a mini review of the Mørch DP-8 tone arm with some measurements. There are not many reviews of such around, but given the unusual design of this tone arm, I am going to make a try. I went from a Linn Akito tone arm to a Mørch UP-4 unipivot tone arm a few years ago, mostly because the bearings of the Linn were going bad. I bought a used one quite cheap and since the installation is quite easy (only differs 1 mm from the Linn tone arm mount), I went for it. I have been interested in the DP-8 as well, but given its price I thought this would never be in my possession. However, a used one came up (barely used at all) I did a purchase.
The design is unusual in that it carries high mass and inertia in the horizontal plane and the bearing is also very damped. It also feels when moving it, very different from the UP-4 arm. The side weights also contribute to the tracking weight since they weights are asymmetrical. I used the 4 g tone arm wand for these tests.
First up is the test of resonance and I used the Denon low frequency sweep for this (4-100 Hz) which is left and right including crosstalk with the Shure brush in up position. As can be seen there is a fundamental resonance around 9 Hz, but also a tonearm resonance at 60 Hz.
Comparing the same sweep using the UP-4 arm the tone arm resonance is not there. So somehow the more heavy DP-8 makes the tone arm resonance show up.
Using the Shure damping brush, the vertical resonance should be damped while the horizontal should be affected only a little, which I also see below. There is a slow decrease of the response from 30 Hz (note: my phono preamp contribute to about -1 dB fall off at 10 Hz), and the fundamental resonance seems to be around 14 Hz. Still there is a tonearm resonance at around 60 Hz.
The resonance is not really showing in the frequency plot script, and probably it is averaged out. There is however another resonance between 300-400 Hz, barely noticeable in the main signal (se also cross-talk signal).
So what does this high inertia do to the response? It should stabilise the response in hoisontal direction where most of the bass is (below 100 Hz). The beats in the song "Billie Jean" in Michael Jacksons album "Thriller" shows one of the benefits.
First with the UP-4 arm:
And the DP-8:
There is significantly less of resonance excited by the beats.
Another potential benefit of the more stable arm is better speed stability. During resonance the cartridge can "scrub" and cause flutter around the fundamental resonance. This is clearly shown in the UP-4 arm, having small peaks around 8-15 Hz.
These peaks vary in level during measurements and can be higher than what is shown in the figure. With the DP-8, I can see only small peaks around the resonance and they are very stable. (Note that the speed is a bit off, the trim pots of the Axis player needs to be readjusted. That is irrelevant for the test.)
Lastly a short note of the subjective sonics. I could upload comparable songs as well, but choose not to in this review. Overall it sound a bit more "quiet" between tracks and also more dynamic, especially the bass region. Stability of certain notes is also evident, together with more detail. On the negative side, there are tonearm resonances there which however, are probably less audible.
Overall, I would recommend this arm if you are into vinyl playing. Yes it is expensive, but so can other "good gear" also be in the HiFi world. I am a bit surprised though that the arm could contribute to the quality as much as it really did. There should be more tone arms designed this way. It really does something.
And the DP-8:
