D
Deleted member 48086
Guest
Hello,
i was about to get a Asgard 3 AMP / Modius DAC stack from Schiit but unfortunately the Modius wont be available anytime soon and in the future probably only with a different chip/design.
So im looking for a good or better alternative to the Modius DAC. 200-300$ +- . I do NOT want to get anything that sounds boring, flat and has a bad or worse soundstage and imaging than the Modius. Can you give me a good recommendation for a good DAC that pairs well with the Asgard 3 ? If you have other stack ideas with different AMPs let me know too. I pair it with a DT880 600 Ohm for now. Sometimes i use the DT990 too.
Thanks in advance for the help
Best regards
Best regards
