Some DACs have higher output on DSD, notably some AKM DACs. And higher is often perceived as better.
Let’s not confuse pre ringing and pre echo. pre ringing is the mathematical consequence of a phase linear sharply band limiting filter. And yes, that only affects signals with energy around the band edge frequency.But pre-echo don’t really show up in actual program material. They show up when you try to capture signals that cover greater than half the sample rate. Music don’t really have those. Most likely candidates are then around clipping and maybe some artificially generated sounds. In practice though, pre-echos are not a concern.
I think it mostly concerns the question about the ringing. correct me if I am wrong.![]()
Audiophile Myth #260: The Detestable Digital Filter Ringing and Real Music...
A blog for audiophiles about more objective topics. Measurements of audio gear. Reasonable, realistic, no snakeoil assessment of sound, and equipment.archimago.blogspot.com
true. Sony did very hard attempts to do the full chain keeping it in DSD. however, they ended up having to remodulate for each step.Almost no such material exists because you cannot digitally process such material very much.
To the contrary, there are many: all SA-CDs mastered and authored with the very first Sony/Sonic Solution DSD stereo editing system or with multichannel-capable digital audio workstation (DAW) implementing Sony Oxford D-MAP processors, such a the Sony Sonoma, latter passed on Super Audio Center, Genex Mix+, Sonic Solution DSD.1 and DSD.x, and Sadie Series 5, have been passed through digital signal processing without change of the DSD sample rate, for reason thoroughly explained by the Sony Oxford's development team in a paper presented at the AES in 2001.Almost no such material exists because you cannot digitally process such material very much.
glad to hear it was used widely by Sony. I had many AES convention chats with Peter Eastty who headed up the Oxford team. They had read my PhD Thesis and other papers on Sigma Delta.To the contrary, there are many: all SA-CDs mastered and authored with the very first Sony/Sonic Solution DSD stereo editing system or with multichannel-capable digital audio workstation (DAW) implementing Sony Oxford D-MAP processors, such a the Sony Sonoma, latter passed on Super Audio Center, Genex Mix+, Sonic Solution DSD.1 and DSD.x, and Sadie Series 5, have been passed through digital signal processing without change of the DSD sample rate, for reason thoroughly explained by the Sony Oxford's development team in a paper presented at the AES in 2001.
According to an insider who has worked for a joint Philips/Sony SA-CD production support office at the beginning of the format to keep track of all SA-CD titles amongst other tasks, the majority of SA-CDs put on the market by mid-2014 (about8,6009100) have been produced on Sonoma DAWs.
Pre-echo is typically an artifact found in lossy compression codecs, not digital filters. The fact that you say you see this in the impulse response already shows that this is just ringing, exactly what I talked about. And no halfway serious DAC has only .1 dB passband ripple. Even a lower-end AK4490 has .005 dB of ripple, and .01 or better is fairly typical, even for budget codecs like AD1938.Pre echo is the mathematical consequence of periodic pass band ripple, ie a pre or post echo causes picket fence ripples in the frequency domain. These periodic ripples is the result of using Parks MCClellan algorithm for equi ripppe filter design.
A seemingly benign 0.1 dB pass band ripple translates into a -40dB pre and post echoes separated by the length of the FIR filter. the echos can be seen more easily if you filter and downsample the impulse response.
Got any reference for this?These echos affect all signals irrespective of frequency content.
Lars is correct, please believe him.Pre-echo is typically an artifact found in lossy compression codecs, not digital filters. The fact that you say you see this in the impulse response already shows that this is just ringing, exactly what I talked about. And no halfway serious DAC has only .1 dB passband ripple. Even a lower-end AK4490 has .005 dB of ripple, and .01 or better is fairly typical, even for budget codecs like AD1938.
Getting DSD converted to 7 bits sounds a bit more PCM-like.
glad to hear it was used widely by Sony. I had many AES convention chats with Peter Eastty who headed up the Oxford team. They had read by PhD Thesis and other papers on Sigma Delta.
yes my
again, please, let’s not confuse pre ringing and pre echo. As i said earlier : pre ring is a consequence of phase linearity and pre echo is sa consequence of periodic pass band ripple.
The pre echo affects all frequencies obviously. That is the mathematical consequence.
I need to get your PhD Thesis then, I am quite curious.
which test do you refer to? reference?It's not audible on a properly conducted DBT volume matched test because of nyquist-shannon sampling theorem and proper anti-imaging low pass filter.
