Modelling driver movement
Holmz
Australia
I am trying to model the cone movement as a finction of the voltage applied to the motor over time.
I see the BL curve, and I could model the current from the voltage and the impedance curve. And generate a motor force.
And I could then subtract from the KMS of the suspension.
And then later the mass of the cone and voice coil, would directly affect the acceleration… assuming that that even matters… which it probablt does more for a woofer than a tweeter.
But there is also the mass of the air coupled to the cone, and the rarefied air on one side pulling the cone, and the compressed air on the other fighting the cone force.
And then if the voice coil is unpowered, it will gradually move towards zero as the KMS pulls it back… and maybe get there more quickly if the impedance across the terminals is high.
Is there a particular website or book that describes the physics that I would need to model all this to first order?
McFly
NZ
Maybe here? Not sure but give it a skim
https://www.acculution.com/blog
He was a guest on erins audio corner a while back, theres a video on his channel. Also Lars Risbo is quite an active poster over in the multi way forum at diyaudio.
NTK
US East
You can take a look at these 2 COMSOL tutorials.
Parent web pages:
NTK
US East
Here is an example of the time domain simulation of a lumped circuit model as mentioned by @René - Acculution.com.
The speaker driver model is separated into 2 parts. The first part is the "lumped parameter" (LP) model for the time domain simulation (see equation 3). The second part is the FEA analyses to model the nonlinear behaviors of Bl(x), Kms(x) ( =1/Cms(x) ), and Le(x) as functions of the cone displacement x. The results of the second part is fed into the time domain simulation of the first part to simulate the actual displacement (and acceleration) of the cone.
Alternatively, you can get the Bl(x), Kms(x), and Le(x) from measurements such as those done by @hardisj
