Thanks for taking the time to make your case in response to my concern. Where can I find a concise description of your method, not a video?
Cheers.
I don't have many videos about the method, only ones that discuss the issues with using generic target curves.
I have another discussing the benefits of using in-situ nearfield measurements.
This is a podcast I did with Brent Butterworth and Dennis Burger where I try to simplify the thought process behind MB.
https://audiounleashed.podbean.com/e/not-that-kind-of-very-special-episode/
One reason I find it difficult to explain is because people are coming from different levels of experience and understanding when it comes to audio. Typically, on ASR, I can be more specific and cut to the chase. But on YT or FB, I have to first teach people about psychoacoustic theory and how our binaural hearing isn't the same as mic measurement. I typically have to undo their thinking about steady state target curves. They bring up "Harman target curves" but are unaware that Dr. Floyd Toole himself has stated that it was never meant to be a target curve, it's a result of good speakers in a room.
MB has been misrepresented by others as a way to remove the room, which is impossible with just DSP. The only way to remove the room is to place the speaker in an anechoic chamber. What MB does is it makes the direct sound as neutral as possible while respecting the directivity index. I know people find it hard to believe that we can get directivity data, but we can and do get reliable data above the transition region. The algorithm is able to detect the transition region and where it needs to change from correcting based on the direct sound to one based on the steady state response. Some aspects are proprietary, but the results speak for themselves. We offer an export that will show what we call the in-room directivity and in most cases, it correlates well with the ERDI from a spinorama above the transition region.
It's all pretty basic and straight forward to me and I think people overcomplicate things. Humans can focus in on the direct sound in a room. Research shows people prefer a speaker with a neutral direct sound and smooth off-axis sound. (No DSP, including ours, can change directivity of passive speakers.) OK, hopefully you have a speaker with decent directivity. So then the target is for the direct sound to be flat. But room correction software doesn't accept nearfield targets, they want MLP targets. So the resulting MLP response curve of a speaker corrected to flat nearfield is what? I don't know. It depends on the room's response, the dispersion pattern of the speakers, and the listening position relative to the speakers and the room. That's why every MLP response curve, aka target curve, is different.
Take any speaker and place in different parts of the room at different distances from the MLP. Take measurements at the MLP with speaker close to a side wall, maybe near a TV, behind an AT screen etc. The steady state response will change for each location even in the higher frequencies because we live in real world where people place speakers in sub-optimal locations. Now let's assume that speaker is perfectly flat anechoic and needs no EQ. By using the same MLP target curve for each location like most people do with their room correction software, they will essentially apply the incorrect EQ above the transition region because each position requires a different EQ to get it back to flat. Maybe if it's away from nearby surfaces, there will be no EQ needed in the higher frequencies. Sure, a single target curve can fix the response below the transition region where we can't really distinguish between the direct and reflected sound. That's fine. No issue there. It's the ruining of the high frequencies that I take issue with.
MB has a unified EQ export that corrects each speaker above the transition region based on making the NF flat, and a unified correction below the transition region based on an average of the room's response to determine when the bass rise starts and how high it naturally wants to rise. So basically, each speaker gets different MLP target curves above transition, but the same MLP target curves below transition when using the Unified EQ. The splice point is determined by the detected transition region.
The hard work was in making the app work on multiple platforms, integrating with as many devices as possible, and supporting people who need extra assistance with the calibration process. That's never ending.
