- Joined
- Jan 6, 2017
- Messages
- 3,948
- Likes
- 4,984
The spinorama give the direct sound information. This Toole says listening tests reveal to be the single most important thing to get right above the transition zone. So how can anything be 'far more important' than that?
Perfectly flat. Got it.OK, let's take an example. Suppose you bought a perfect speaker. The designer used an anechoic chamber, placed a mic 1m from the speaker, and tuned it until it is perfectly flat.
Sure, but that’s not the direct sound, that’s the summed sound. The direct sound is still flat, except for a tiny attenuation due to air absorption, which is dependent on humidity and I think safe to ignore for domestic room sizes.You take it home and put it in your room. You place your mic 1m away and you see a perfect flat response above the transition zone, below this it's a dog's breakfast. You move your mic 2m away. The frequency response starts to fall. Re-measure at 3m, 4m, etc. You will see that as you get further away, the falling frequency response becomes more pronounced.
The primary determinant of tonality is the direct sound. The reflected component is a secondary determinant, sure, but you don’t want to worsen the primary determinant. Out of the frying pan into the fire.Thus the tonality of the speaker depends on listening distance. Sit too far away, and you will get bass heavy sound with a pronounced downward treble tilt, regardless of what the predicted in-room response says. You don't have to take my word for it. Get your mic out and go check it for yourself. Why bother with the predicted in-room response when you can easily check your actual room response?
Like I say, direct sound is king, and none of your examples above affect the direct sound. If your ‘great unwashed public’ insist on doing ‘all sorts of awful things’, then they are creating compromises that, I assure you, are more likely to be harmed than helped with in-room EQ.The fact is, once loudspeakers leave the sanitized test conditions where they were designed and into the great unwashed public like you and me, we do all sorts of awful things to speakers. Just look at some of the systems posted on ASR. You will see coffee tables in front of speakers, bookshelf speakers on computer tables, bookshelf speakers in the corner of a kitchen, dipole speakers pushed up against the front wall, and so on. So never mind what the Spinorama says. Spinoramas are artificial, what matters is what you measure.
I tried to find a reference for what I am about to say, and gave up. But in a nutshell, Toole asserts that the evidence is that humans unconsciously detect the direct sound separately from the indirect sound, and prioritize it. Hence the anechoic data is still relevant to in-room listening. This makes it inappropriate for us to measure summed sound, and think that it determines what we perceive, for example tonality.
Toole suggests tone controls in order to deal with less-than-great mastering. He does not recommend them as a way to fix room sonics or speaker FR. Our best options above the transition frequency are to buy speakers with a flat and smooth anechoic FR (ie direct sound) in that range and don’t muck around with them, or, second best option, buy speakers that are amenable to EQ and EQ their direct sound only…to be flat and smooth. NOT to measure their summed FR in the room and deal with that as a tonality issue.Toole himself says that "broad tone controls" can be applied to the upper frequencies. Granted, the Magic Beans app does not do that, its aim is to analyse and remove the "room transfer function". But still - we need to realise that it's not only freqs below the transition zone that are affected by choice of speaker placement and MLP, but also the upper frequencies.
cheers
