Constructive criticism (only because I am frantically redoing similar results):
While there is no guaranteed way to know for sure, it seems that your azimuth adjustment is off. Based upon going through this again and again, it is likely that your channels will match up better FR-wise if adjusted. It also seems to me that the useful channel balance number is in between, so the stylus is at around -23dB.
I too am seeing my right channel 2nd harmonic higher than the left channel for most--but not all--of my measurements. I am trying to figure it out. I made this by playing with tracking force and anti-skate. I helps on some cartridges, but not all. Still, this shows how these measurements can help with set-up.
Just for reference, this about the widest channel balance difference I will post -- unless I no longer have the cartridge. Then I write a disclaimer. I understand these all can't be perfect--mine aren't--and that this is inherently a part of the game. Some turntables were not meant for proper setup and we are now really seeing these things under a microscope. But I do like channel balance here because it forces you to be honest and it is a good sign of dependability.
HOT TIP: Put one of those little rings that often comes with cartridge packaging under the side that shows a higher channel balance, between the cartridge and headshell. In your case the left side. So have the screw go through it and hold it in.
I'll post an example of what I am posting later.
Is there a particular reason you are using side B of the clearaudio? Side A seemed better to me.
And what do you have for
Anyways, that's a super helpful measurement. Nice to see a compatible Jico.
