And what is your definition of "frequency response is the same" and "level matched"?It was a simple question… if the frequency response is the same, and they are level matched, will all cartridges sound the same?
How close is close enough ?
My thoughts are “if” several different cartridges achieved the same frequency response adjust their output to match… they may sound similiar.And what is your definition of "frequency response is the same" and "level matched"?
I believe your right, and that’s been my experience over the years. Although I have never tried to achieve a flat frequency response right from the get go.I would say no...we are talking about a tiny little motor, and distortion profiles would pretty surely be very different.
A ruler flat frequency response, but one cartridge has 1% distortion at 800Hz and one has 10%, they likely won't sound the same.
When you are dealing with transducers like speakers, headphones and cartridges it isn't quite as easy to characterize them audibly through basic measurements as it is with most SS electronics.
Not sure if you have seen this Ortofon patent that talked about what can cause distortion in cartridges:I’m just trying to learn.
audiosciencereview.com
Thanks, I’m going to make that part of my morning read.Not sure if you have seen this Ortofon patent that talked about what can cause distortion in cartridges:
MM vs MI vs MC
On the other hand, an iron core cross, where the typical MC-coils are wound upon, produces a significant amount of "Barkhausen-effect noise... The degree that these 'problems' influence what one hears in the living room is a big question. What we hear often results from a combination of...audiosciencereview.com
Interesting article, thanks again. Ortofon is one of those companies that know us vinyl guys like to read, and there is no shortage of literature on their website. I believe they do moving magnet, and moving coil very well. I have their Ortofon black and it slightly edges out my old Shure and Stanton cartridge’s as far my preference goes, but there’s no doubt that I still like my vintage cartridges.Not sure if you have seen this Ortofon patent that talked about what can cause distortion in cartridges:
MM vs MI vs MC
That’s why I said there’s no shortage of literature on their website, and it’s all about marketing. That being said their 2m black series is done well, but I cannot vouch for their other offerings.I bought a Technics SL-220 turntable with the Technics EPC-270C cartridge, after the data about moving mass for the Technics EPC cartridges was shared. It is after my post I just linked above. Big thanks to @JP
The old Ortofon cartridges might have been pioneering, but I don't think the modern Ortofon products are good anymore. Glad for the Ortofon pioneers, but the modern company has some unfortunate audiophoolery.
Well, if the new Technics integrated's phono preamp works as advertised the differences might be minimized. From Technics below.It was a simple question… if the frequency response is the same, and they are level matched, will all cartridges sound the same?
So basically they solved every problem plaguing us vinyl guys for the last 60 years, and rolled it into one package?Well, if the new Technics integrated's phono preamp works as advertised the differences might be minimized. From Technics below.
Intelligent Phono EQ
The Intelligent Phono EQ mounted in the SU-R1000 utilizes the sound quality improvement technology for DSP, which Technics has accumulated through the development of LAPC, in order to realize high sound quality not possible with analogue Phono-EQ. This technology consists of three parts: 1. Accurate EQ Curve, 2. Crosstalk Canceller and 3. Response Optimizer. These functions can be turned ON/OFF to suit the user’s preference.
Accurate EQ Curve – Madepossible by hybridanalogue/digital circuitdesign
An accurate EQ curve is achieved by a hybrid analogue-digital system. The high-gain low-pass filter (LPF) performs analogue processing, while high frequencies are raised after the A/D conversion. The use of the 40-dB LPF(Low-pass filter) in the analogue region suppresses the bit loss during digital filter processing, and high frequencies are raised with high accuracy in the digital region to achieve a high S/N ratio.
Crosstalk Canceller - Formeasurement andimprovement of crosstalkcharacteristic unique toeach cartridge
This function measures the crosstalk characteristic of the installed cartridge by using the crosstalk measuring signal recorded on the Calibration Record bundled with the SU-R1000. It then performs reverse-correction using the built-in DSP to achieve significant improvement of the crosstalk characteristic. This results in a more precise sound image and a wider sound ambience.
PHONO Response Optimiser - For correction of disturbance in cartridge frequency characteristics
This function measures the frequency characteristics of the installed pickup cartridge by using a TSP (Time Stretched Pulse) signal recorded on the bundled Calibration Record, and corrects characteristics disturbance. It corrects the effect of impedance matching between the pickup cartridge and the phono equalizer to reveal the true sound quality of the cartridge. This technology aims to improve sound quality by avoiding a selector such as a switch in the high-sensitivity phono input line for the removal of the possibility of noise disturbance.
I think it is interesting that they spent R&D money doing this for what many considered a "dead" format. No idea if it actually works.So basically they solved every problem plaguing us vinyl guys for the last 60 years, and rolled it into one package?
I’m sure it sounds fine, but there’s a lot of marketing in that article IMO. Also in my opinion, we never know how somethings going to sound until we get it in our room. Again they know us audiophiles are readers, and like I said I’m sure it sounds great.
Where is the fun in not first spending $10,000 to get to this point? Just kidding.
I haven't restored it yet, but have the service manual. The total price was less than 100 dollars for the turntable that still had the original cartridge. That's why I don't want to buy expensive cartridges anymore, when I can just scoop vintage goods up, restore them and sell with a profit margin. I didn't plan to keep the turntable. It was just part of the deal that was in my local area.Sounds like a nice turntable, how do you like that combination?
I think there’s a lot more people spinning vinyl than I/we realize. If you listen to the chatter online and the against vinyl crowd, no one would ever dare play such an inferior media. There is a time when I want perfect sound, and there’s a time when I want to try to get my vinyl playback sound as good as it can. For me I’m there, and I know not everyone is going to like how mine sounds, and that’s OK. I feel no need to defend my preferences, especially to people that are dead set against it.I think it is interesting that they spent R&D money doing this for what many considered a "dead" format. No idea if it actually works.
I never gave up my vinyl, but the level some of the folks go to with measurements and testing is astonishing! Hopefully, there is still time for listening to music at the end of the day.I think there’s a lot more people spinning vinyl than I/we realize. If you listen to the chatter online and the against vinyl crowd, no one would ever dare play such an inferior media. There is a time when I want perfect sound, and there’s a time when I want to try to get my vinyl playback sound as good as it can. For me I’m there, and I know not everyone is going to like how mine sounds, and that’s OK. I feel no need to defend my preferences, especially to people that are dead set against it.
You guys are doing a great service to the ones that don’t get or understand just how good vinyl can be. I welcome any new talk (actual working tweaks) about the subject, especially when most of what we have in our vinyl rigs has been perfected for decades.
I wholeheartedly agree with that statement. I get it, and I lived it for years, and if I want to step up my vinyl experience where do I go from here? My original point was if my ultimate goal is to get a flat FR at my listening position, why would I do it twice?I never gave up my vinyl, but the level some of the folks go to with measurements and testing is astonishing! Hopefully, there is still time for listening to music at the end of the day.
...if I want to step up my vinyl experience where do I go from here?
Nice, but I’m afraid I can’t further your vinyl experience lol.Where? Well, JJ, if you've pretty much done the analog thing both there and back, there's really only one place you can go from where you are. Come over with your soldering iron and help me get this thing working.
I'm on a roll. Recently got continuity from an old Grace 707 that was having the hiccups. I'm happy about that. But this? I have to tell you, I don't think you've ever passed the audition until you've worked with one of these! I understand it was originally conceived/designed in Australia, manufactured in Japan, later modded in the US of A. The question to ask about all that is, 'why'? But I don't ask questions anymore. Mostly because I don't want to hear the answer.
It's my next project. Might make me give up analog. Entirely possible.
PS: if anyone has any idea where exactly the black ground wire from the plug-in base into the arm should be soldered, I'd be happy to know that.
